Results 1 to 7 of 7
Thread: Valves good at 45,000
    apriliaforum Junkie Capsil21's Avatar
    Romeoville,IL
    Thought I would report that after having the valves checked with 45,000 miles, all were in spec. and have never been adjusted.
    Very sweet!
    apriliaforum expert bikeral64's Avatar
    Apr 2009
    Madley, Hereford, England
    That's good to hear, as mine has done 35000 + and I'm pretty sure they haven't been touched either. My motor sounds real sweet and quiet, so I'm leaving mine for a while longer.
    Mackay Qld Australia
    Yup,mine were in spec at 40-ish-k klm too
    will check again at 100k klm/63k miles
    JohnG.
    '02 Capo..."take the road less travelled..."
    http://www.youtube.com/watch?v=j7XDAfD6E8o
    May 2010
    USA
    all my intakes were at .004 at 40K miles
    and two exhaust were out....I'd have to look at what I wrote.
    damned thing runs like a raped Ape....oh, wait, it IS a raped Ape
    Dec 2009
    SoCal, US of A
    Rotax makes aeropower plants as well.
    Yup,Rotax are tough as...
    BTW,RH inlet on the rear pot was
    at the lower end of the specs at just
    over .12mm but I'm not worried.
    Many motors run much closer than this
    especially in California where they make
    some aircooled Guzzis run half the normal spec!
    JohnG.
    Scottsdale, AZ
    Quote Originally Posted by Capsil21 View Post
    Very sweet!
    That's the best possible outcome. I've had to adjust three valve shims in 60,000 miles, but the reason was odd. The clearance had opened up a bit, so I calculated the shim required to get back into specs. When I installed the new shim, the valve was too tight. As it turned out, the original shim had been dimpled by the valve stem, which is smaller diameter than the shim. So measuring the shim with a micrometer didn't show the thickness actually "seen" by the engine. Installing a new shim of the original size put the clearance back in specs. I don't know why those shims were dimpled. Maybe they weren't properly hardened. Regardless, I tossed them out rather than attempting to flip them over and reuse them.
    Stu
