some grubby photos - as folk have asked:
Grubby Falco
Grubby Falco
Need user/password to access?
Chuck Vicknair
Lititz, PA
Should be open to all?
Doesn't work for me, either.![]()
'03 Black/Silver
ARROW CF slip-ons & chip
Genuine Aprilia Falco Luggage (panniers)
Puig Dark Smoke touring screen (thanks Mfed)
Ohlins shock....not installed (yet)
“An intelligent person can rationalize anything, a wise person doesn't try.”
― Jen Knox
Ok will fix it
I think this is actually Ridersite that is stopping stuff - so try here
yep..that works. Is the RSV tank made out of welded sheet-steel (instead of cast aluminum like the OEM bird tank) ?
'03 Black/Silver
― Jen Knox
Yep -- lot lighter
And allows Mille headers and exaust to be i
Fitted
Why not just embed the photos with [img] [/img] tags instead of making people click a link?
Because I posted it in a hurry... So I was being lazy!
I'd be tempted to remount that on some kind of flexible rubber bobbins - I know from experience that the top bracket on the steel tank can fracture, leak and maybe even come off. It's a bitch to weld back too - oily, thin material etc.
SL1000 Falco + Mille R engine, ECU & Swingarm + Mille Scorpion TI exhaust + Renthal risers + Belly pan
FOR SALE: Falco SL Carbon Exhaust
WANTED: Falco right-hand lower panel in Fire Red
