Hello All
I need some help. I weight 75 kgs / 165 pounds
The bike starts to wobble in corners, if i lean harder it goes away but comes back when i settle into a constant turn.
I have the old style front end, spring in left side only.
What are the standard or recommended suspension settings for the front and rear.
Front:
What should the oil levels be in either fork leg?
How far should the front forks stick through the yokes?
Spring setting (nut sticking out of top)
Rebound setting?
Is there no compression setting on the front?
Rear:
Compression
Rebound
Spring? (how much thread above nut) or what should the sag be?
Many thanks
Ryan
