Results 1 to 9 of 9
Thread: Always drain the FCV???
    apriliaforum newb loudes13's Avatar
    Dec 2010
    Galt's Gulch
    Is it always absolutely necessary to drain the Flow Control Valve (FCV) for every oil change? If so how much oil is up there? This link makes it sounds like there's very little oil up there.
    http://xvasylum.wikidot.com/guide:pr...ange-procedure
    I only have 200 miles on my oil, but I'm getting ready to hit the Tail of the Dragon. I want to change the oil/filter before I go.
    If it's ok to ignore the FCV, should I put a tiny bit less oil in or should I do the full job?
    The main reason people drain the FCV is that when you unscrew the plug, all the oil drains from the tank also (easier than unscrewing the tank plug).
    If you first drain the oil from the tank and the plug on the left side of the motor, you will not get much more from the FCV.
    Just be very carefull not to overtighten, the threads on the crankcase are soft.
    The FCV does not go bad as most here believe they do.
    In all these years of servicing and rebuilding these motors, I've yet to see one causing problems.
    The scratches on the side of the FCV are not a concern, the top of the valve is what is sealing the pressure relief port. I only replace the FCV when the top of it is snowing wear.
    apriliaforum expert kimzx1000r's Avatar
    Sep 2007
    Illinois
    I agree with Amauri on the FCV, I have never changed mine and it looks just like it did the first time I took it out. I do drain my oil through it and find it easier. Gives me a chance to inspect it.
    Jun 2007
    australia
    Will all the oil drain out FCV? I take the out the FCV, tank and engine plugs to drain the oil.
    apriliaforum Junkie popik's Avatar
    Edmonton, AB
    what Amauri said. Pull the FCV and pull the filter...plug them back up...add oil and go fast!
    The FCV will drain all the oil out of the tank, but not all the oil in the crankcase.
    There are four things you must drain:
    1- tranny plug
    2- FCV
    3- oil filter
    4- crankcase plug (just in front of the tranny plug)
    Do it with a warm motor.
    apriliaforum expert Markee's Avatar
    Feb 2008
    Melbourne, Australia
    Quote Originally Posted by kimzx1000r View Post
    been doing this for the last 2 years
    www.supermotoaus.com APRILIASXV550
    Quote Originally Posted by Alice Racing View Post
    The motor and maps are race orientated, and want gunning !!
    www.moto-extremes.com
    apriliaforum expert proslider's Avatar
    Mar 2009
    Blairsville, GA
    I only pull mine about every third oil change. That way I don't have to remove the belly pan. I find it easier to drain the oil tank and believe I am less likely to strip the threads on it. Plus if I did the cost would be less.
    "Follow Me I'll Show You How To Crash"
    Current Garage:
    2009 Aprilia 550 SXV
    2006 KTM 300 XCW
    2001 KTM 520 EXC
    The Departed:
    2001 Yamaha R1
    1997 Yamaha YZF1000
    1997 KTM 620 RXC
    1994 Yamaha YZF750
    1984 Yamaha FJ1100
    1982 Yamaha 750 Seca
    1980 Yamaha 600 Maxium
    apriliaforum expert Waxerdog's Avatar
    Mar 2004
    Los Angeles
    I haven't used the tank drain in a long time. Going the FCV route is great, says one a washer too. Plus you have a chance to check the the valve and polish it up as needed.
    To the "State of California" -You can have my "Akrapovic" when you pry it from my cold dead fingers!
    2010 RSV4 Factory - '09 SXV550
    '02 R1, '04 RSVR, '02 RSV
