Results 1 to 5 of 5
Thread: GPS tracking device for scooters
    Los Angeles near da beach mon
    Anyone have info on installing a GPS tracking device that is relatively cheap i.e., no monthly service fees?
    apriliaforum expert TheChef's Avatar
    Aug 2010
    Surrey,B.C
    I just use my iphone.
    09 SR Factory
    "Boo"
    Malossi BBK
    2.8.0 ECU LEOVINCE ZX-R ZMR7AP .035
    MALOSSI Multivar 2000 Yellow BGM clutch springs Green contra spring Reeds VL13
    8gm Dr Pulleys Husky Watertrap
    Gen III Adjustable High Gain Tuning Regulator 118psi
    Woodruff key BGM pod filter
    Fuel pump fix 40mm riser Stretch kit
    113kph.
    6"3 225lbs.
    apriliaforum expert shrubman's Avatar
    Nov 2008
    Athens, Georgia USA
    I assume he means something like LoJack.
    Shrubman
    2009 SR50 R Factory
    Engine:
    HGT PFI Conversion
    HGT-Modded Bing 26mm Throttle Body
    Malossi 86CC Cylinder
    Malossi MHR Big Bore Exhaust
    Malossi VL13 Reed Valve
    Pro Porting Intake Manifold and Spacer
    Pro Porting Double Layer "Air Plus" Air Filter
    Transmission:
    Malossi Multivar 2000 MHR Team (2008 Model)
    Malossi 14/39 Primary Gears
    Malossi Delta Clutch
    Malossi Kevlar Belt
    Other:
    Stage 6 Adjustable Shock Riser
    HGT Billet Aluminum Brake Levers
    Buzzetti Side Stand
    Motorkit Rear Hugger
    Feb 2011
    Seattle, WA
    How will said GPS device send the data? If needs a service to do that, which in turn costs a fee.
    Unless you are trying to track your son/daughter from going to places they shouldn't, then there are devices that you can attach to the bike, hidden, that will store all routes and speeds that you later download to your PC.
    2007 SR50 - Morini
    ECU de-restricted by HGT
    Leo Vince ZX pipe - Chrome
    Malossi sponge air filter
    3 degree woodruff key
    Malossi MultiVar 2000
    Malossi white contrast spring
    Malossi Torsion Control
    Dr Pulley 7gr sliders
    Malossi Special Belt
    YSS 300mm rear shock
    LED corner lights
    Hella horn - Beats the stock horn!
    *pending to be installed*
    Malossi 70cc BBK
    Malossi V12 reeds
    Dr Pulley 7.5gr sliders
    HGT Fuel Regulator
    Kobalt Water Trap
    **Needs repair**
    Battery dead from Winter storage
    Jul 2010
    Miami, FL
    There are real time GPS trackers available..
    They are more popular overseas but here is one for the US made by Scorpio: http://www.bikebone.com/page/BBSC/PR...IOALARMS/rLink
    There are no harness adapters for an Aprilia, but I am sure someone could buy the Vespa harness or one for another motorcycle and make it work on an Aprilia scooter.
    It has free data/SMS services for the first year, after that it will cost $10/month.
    In europe they have a larger variety of these things.. here is one made for scooters that scooter-attack and another site sell:
    https://www.scooter-attack.com/shop/...S-Locator.html
    Being careful with where I leave my scooter and sticking a cable and rotor lock on it is much cheaper than a $500+ lo-jack unit for something I only paid $1500 for.
