Results 1 to 15 of 16
Thread: niose at the front end ????
    apriliaforum Junkie caponord's Avatar
    Feb 2011
    Adelaide
    Angry niose at the front end ????
    After taking my beast for a spin, i noticed a noice or collaps at the front end of my capo,
    when coming of the throttle i feel and hear a knock like collaps, it feels like the fork has play, or a bearing, its like something is loose, I dont know how to explain it better.
    Wondering if any of you have experienced anything like it.Now I am to worried to ride my bella. Help!!! Its a bit hevy to keep the front end of the ground and check.
    I LIVE TODAY AND TOMORROW I DONT KNOW !!!!
    DON'T FOLLOW THE PATH, BUT LEAVE A TRAIL!!!!
    If you going to be up my arse, at least pull my hair!!!
    Even you can have a body like mine, all you have to do, is neglect it !!!!!
    Melbourne, Australia
    Sounds like front wheel-bearings... You shouldn't ride the bike till they are fixed - luckily it's a quite easy, quite cheap job.
    Here's the test-method:
    Do you have a centre-stand? If so, put the bike on it and put something heavy (I use my wife....) on the back seat to lift the front wheel off the ground.
    If no stand, get two car axle-stands with a bar or plank between them and lift the front wheel up.
    First, check the steering bearings (starting from the top): Gently swing the forks left to right; do you feel anything? Does the steering settle straight ahead? Is there a grinding feeling, or any resistance?
    If the answer is no, that's not your problem.
    While you're there, do you see anything that looks bent or broken, bolts missing, anything loose? Check the front mudguard and that both calipers are bolted on tight. Is the front axle & its 4 pinch-bolts all tight?
    Now hold the front brake on with the wheel facing straight ahead and try to pull the wheel backwards and forwards - look at both sides of the centre of the wheel, where the axle goes through; is there any movement? Note, this is also a test for the steering bearings.
    Finally, turn the wheel all the way to one side or the other and try to lift the bottom of the wheel towards you, while pushing the top away; any movement? If so, it's the bearings on either side of the front wheel hub.
    Let us know what you find.
    I'd like to die on Mars. Just not on impact.
    The appropriate number of cylinders for any motorcycle is two.
    apriliaforum Junkie nerald's Avatar
    Dec 2007
    Cumbria
    Might be something simple like floating disks rattling. Do a search for brake disk washers. I had a similar issue not too long back. Bend the washers and put them back, sorted.
    08 ETV 1000 Caponord
    Multistrada 1200
    Quote Originally Posted by nerald View Post
    Bike doesn't have ABS - fixed rotors.
    apriliaforum Junkie GH_services's Avatar
    Aug 2010
    watford, herts
    Quote Originally Posted by Precis View Post
    mine doesnt have ABS but it does have floating discs
    Feb 2011
    Adelaide
    Thanks guys, I will give it a good check,
    Is it possible that the forks are giving in? I found a mark where the fork at the top is clamped to the steering bracked, I'l make a pic. and post it, maybe we can mesure the distance from the plastic cover end where the fork goes in to the top where the clamp holds the fork and see if the mesurements match.
    Regards, Alby
    Apr 2007
    Basingstoke, Hants, UK
    Quote Originally Posted by GH_services View Post
    You probably have aftermarket disc's / Rotors, as the early pre ABS capo's had non floating disc's.
    (2003 Infinity Blue Capo)
    (1990 Kawasaki ZZ-R 1100C1)
    Feb 2011
    Adelaide
    this is what I noticed at the top of the fork
    while checking the bike I noticed at the top of the fork this marking just under the bracked, looks to me that it mait of shifted.
    If anyone can make something out of the pic and confirm or not.
    Thank in advanced for any input>
    regards,
    Alby
    Hard to say Alby, but I think that's just showing how much fork travel you've used - all of it! The noise you heard might have been the mudguard hitting the fairing?
    When you bounce on the front suspension, does it return to its normal position?
    Try putting a zip tie around the fork leg and see how far it gets pushed up - but only after you've checked those wheel beraings!
    Feb 2011
    Adelaide
    Il do that steve,
    just that I have never noticed it like that.
    The feeling of movement is only when coming off accelleration and back on and off, you know what I mean? when weight distribution happens.
    Rgards,
    Alby
    Nov 2006
    Houston
    I will bet your wheel bearings are shot. You need to get this checked out and soon.
    Bikes:
    apriliaforum prov-nov pikeymic's Avatar
    Jun 2010
    Lancashire
    Mine had buggerd wheel bearins and floating dics. Easy fix
    YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE.
    Feb 2011
    Adelaide
    is it possible, that having a loose timing chain,can give you the feel of slite movement, when coming on and off throttle? Its doing my head in!!!!!
    Timing chain? Inside the engine? No.
    Maybe your drive chain to the rear wheel is tired, dry, loose or just plain finished - THAT could make a noise like you describe.
    Feb 2011
    Adelaide
    what are the obvious visual signs of drive chain being finished? i just cleaned and lubed it tuesday, and dident notice any signs of wear. It could be that im not seing the obvious.
