Results 1 to 13 of 13
Thread: Evolution conical shaped twin mufflers
    apriliaforum expert Priest's Avatar
    Mar 2007
    Croatia
    Don't ask, just look and listen. And enjoy, of course.
    [ame="http://www.youtube.com/watch?v=D9edttnDLyw"]YouTube - Konusni AkrapoviÄ - Tuono[/ame]
    Apr 2009
    Tallahassee, Florida
    Boy, those do sound (and look) really good!!!
    apriliaforum expert twin4me's Avatar
    Jun 2004
    Nurburgring... been, there, done that, got the sticker
    Priest - your on-going prayers to end up with all the good stuff must really resonate with the man upstairs.
    You really only need three things for bike maintenance
    If it moves and it shouldn't - Duct tape
    If it doesn't move and it should - WD40
    ...and if it falls off and you want to reattach it - Cable ties.
    apriliaforum Junkie Aussie Factory's Avatar
    Jan 2010
    AUSTRALIA
    Man they look crazy. Very cool.
    apriliaforum expert EditTim's Avatar
    Jan 2004
    Atlanta, GA
    Hey Priest, what is the diameter of the inlets where the link pipes attach to the cans, and, where can one source these?
    Very Nice!!!!
    Also, could we get a better pic of the cans with the link pipes?
    Tim
    '07 Tuono Factory
    Leo Vince cans, 15/42, CF bits, Rizoma bars, bar ends, & mirrors, Austin Racing rear sets w/ GP shift, Factory Pro Evo shift star kit, radial clutch/brake, CRG levers, Evotech hangers, Powerbronze, billet sidestand, 6k HID, AF1 link plates, lightened flywheel, Öhlins TTX, BSTs, Bazzaz Fi-TC
    '04 Futura in Gloss Black
    Factory Pro shift kit, 15/43, GP shift, CRG's, Evo clutch slave, Bef semi-full (ceramic coated), Wilbers shock, 6k HID, Mille fork lowers DLC coated w/ Öhlins and 4-pad calipers, radial clutch/brake, lightened flywheel
    '03 Mille R Colin Edwards Rep #84
    Track bitch... Motobits rearsets. Sharkskinz & Non-CE tank in Aprilia "Red" (street plastic safely stored), Engine & suspension work.
    Stroudsburg, PA
    Do you have to get new hangers or make an adapter plate?? I see they are only zip-tied in and the bolt holes do not appear to line up. Sick looking pipes btw!
    Jan 2004
    Atlanta, GA
    Quote Originally Posted by DucmanDan View Post
    Do you have to get new hangers? I see they are only zip-tied in and the bolt holes do not appear to line up. Sick looking pipes btw!
    Hmmm, Akrapovic doesn't list their conical pipes for Aprilia while they do for other brands... Priest?
    Tim
    '07 Tuono Factory
    Mar 2007
    Croatia
    Quote Originally Posted by EditTim View Post
    Very Nice!!!!
    The diameter is 65mm. Unfortunately, you can't find these... I'll post some more pics when things are done. We are going to modify some linkage pipes length.
    Mar 2007
    Croatia
    These days this issue will be correct. When done, you'll be first to see it.
    Mar 2010
    Seattle, Wa
    Quote Originally Posted by Priest View Post
    The diameter is 65mm. Unfortunately, you can't find these... .
    Is this because they are a product that is in development, or are they originally intended for another make and model?
    Mar 2007
    Croatia
    Quote Originally Posted by ResoundingYes View Post
    Unfortuntely, they will not be in production. I have a fortune to try this only one and to see how much they gonna last at a two cylinder bike.
    apriliaforum Member theprophet36's Avatar
    Jul 2010
    Enfield, CT
    Me likey
    Nov 2006
    Houston
    Sounds nastah!
    Bikes:
