Results 46 to 60 of 65
Thread: ****Correct battery replacement procedure. Must read.
  1. #46
    Westminster, CA - USA
    No, this is not for the Tuono, only for the 04 -09 RSVR.
    Read my first post again and pay attention to where it states:
    "vehicle with the MARELLI instrument panel (identifiable by the + and - buttons to the left of the display"
  2. #47
    May 2013
    greece
    I thought they use the marelli unit,I'm really sorry for my post.Some times even if you are certain about something,it turns to be wrong
    Amauri,your help in this forum is priceless
  3. #48
    Quote Originally Posted by geobarb777 View Post
    Easy to misinterpret the Aprilia bulletins sometimes, you have to read very carefully.
  4. #49
    Jul 2014
    Earth
    recently change my battery.. as it cant hold the power anymore..
    doing the same procedur.. but i leave it switch on for about 30-40seconds (not connected all the headlight bulbs)
    turn it off.. and then turn it on back n fired it up.. everythings is ok.. it still recall the old odometer readings..
    except rev limiter and clock need to be adjust..
  5. #50
    Jan 2015
    wigan
    guy who I bought it off just did this two days ago , can it be changed back to 6k ??
  6. #51
    Jul 2014
    Earth
    i'v done this method twice.. and still recall my old odo mileage..
  7. #52
    apriliaforum newb jimsfactory's Avatar
    Mar 2012
    melbourne, Australia
    Great help thanks Amauri!
    RSVR Factory 05
    - EVO6 system
    - PCIII & quick shifter
    - Gilles rearsets
    Daytona 675 (track trim)
  8. #53
    apriliaforum prov-nov Black04Fac's Avatar
    Sep 2007
    Manteca, California
    Well it worked one time, but this time mileage info reset to zero today, Dam it!
    2004 Factory
  9. #54
    Sep 2007
    Manteca, California
    update:
    I had taken battery out to due a Desulphation and recovery procedure, to see if this actually works,( I own an Optimate 4 charger). After my charger compelted the procedure, I reinstalled the battery and that's when milage went to zero and bike still would not crank. So that test fail even though charger indicated charge was good. So I replaced battery today with OEM, and for some reason my mileage came back and everything else went to default settings. I don't know why it came back, but glad it did.
  10. #55
    Dec 2015
    uk
    just thought i would check if anyone else has had the clocks reset on them after taking the battery out even following the battery replacement procedure? no key in the barrel and went through the steps prior to starting the bike.
    no biggie as they have already reset once before just curious.
  11. #56
    Jan 2016
    East Coast
    I just purchased a used 2004 RSV Factory, and have found some great info on this site, as well as parts from AF1. If this is correct about the battery draining like this, and resetting the odometer to zero, that should be enough grounds for some kind of class action lawsuit against Aprilia. Resetting the odometer to zero has got to violate all kinds of Federal laws...
    Robert B
  12. #57
    apriliaforum newb Crownan's Avatar
    Mar 2014
    United Kingdom
    Interestingly, myself and someone else have had the problem of when disconnecting/reconnecting the battery the RPM would idle at 3,000! The 15 second procedure rectified this on both accounts.
  13. #58
    apriliaforum newb tweak's Avatar
    Jul 2007
    Lincs, UK
    I've followed this to the letter today. ODO now reads 00000 but I've not started it yet. What's gone wrong?!
    riding RSV 1000 R // RS 250 rebuilding
  14. #59
    apriliaforum prov-nov Dream Corrosion's Avatar
    Sep 2016
    Alabama
    Sorry for splitting hairs, but does the kill switch button need to be 'in' or 'out' for this fixit?
  15. #60
    apriliaforum Junkie mwlehman's Avatar
    Apr 2013
    I just took a 9v battery, soldered wires to 9v and alligator clips , hook it to bike cables before I disconnect 12v battery, it supplies enough current to bike so everything stays as it should...or do same with spare 12v battery, small gauge wire and alligator clips
