Results 16 to 30 of 66
Thread: ****Correct battery replacement procedure. Must read.
    apriliaforum Junkie backys's Avatar
    Dec 2005
    Greece
    I wonder what the ECU is doing those 15 sec.
    Self check maybe?
    -2004 RSVR Factory Red
    -Nera Triple Clamp
    -Woodcraft Clip-ons
    -19x20 Billet Brembo Brake M/C
    -16x18 Billet Brembo Clutch M/C
    -Carbon Labia,Flapper Diabled
    -Open Ironbite Airbox with DNA Air Filter
    -Akrapovic EVO6
    -Map2
    -High Grade Steel Link Plates
    -Gilles Rearsets
    -Gilles Chain Adjuster
    -15/40 520 Chain and Spockets
    -Ohlins Set-Up by Poletti Racing Italy
    Mar 2011
    Mass
    Is this the cause of the stators burning out?
    Aug 2010
    Seattle, WA
    Just to clarify. All I need to do is turn on the key (like I would do if I was going to start up the bike), wait 15+ seconds, then turn the bike off again. That's it?
    I bought my 04 RSVR last summer and I've noticed the battery seems to not keep a charge long. I'm wondering if the previous owner replaced the battery without doing this. If so, is it too late to do this?
    Westminster, CA - USA
    Anytime I replaced a battery on a 04-09 RSV in the past, I would adj the clock and RPM light before starting the bike.
    Without knowing it, I was performing the "key on, wait 15-seconds before start" proceedure.
    apriliaforum expert Stick's Avatar
    Jul 2008
    Clinton, Indiana
    damn...glad I stumbled onto this. Going to get new battery tonight! Thanks amauri.
    #1 Forum Coprophiliac
    mmmmmmmmm.....Panty Gravy!!
    I have bad luck....If it were raining vagina's...I would get hit in the head with a Dick!!
    apriliaforum newb merc-factory's Avatar
    asia
    my battery lost its charge since it sat for a long time...so i took it off and had it charged...
    now this is the same battery and not a replacement...but i didn't do the 15 second procedure. do i have to disconnect it again and do the procedure?
    thanks.
    2008 Aprilia RSVR Factory...currently Loving it!
    2008 Yamaha R6...sold
    2003 Honda CBR600RR...sold
    apriliaforum prov-nov mobee's Avatar
    Jan 2007
    Hong Kong
    thkQQ
    run run run mobee run.....
    Wii 7457 5601 3624 0786
    ________________________
    06' RSVR
    00' ZX6R
    98' CBR919
    93' YZF600
    92' Zephyr550
    8x' RG250
    apriliaforum expert locknload's Avatar
    Jan 2004
    Christchurch New Zealand
    Obviously, when the multimeter is disconnected, it is as if the battery poles were disconnected again, so the aforementioned procedure must be repeated without the multimeter.[/I][/COLOR]
    I do not follow this part. Are you saying that at any time you check your battery with a multimeter you have to do the key on wait 15secs and then key off. Cheers
    Sweden, Linköping
    Quote Originally Posted by locknload View Post
    If you check the voltage using the multimeter it is not necessary.
    What Amauri wrote was if you had been measuring the amperage which requires the multimeter to be in series with the battery it is necessary.
    Jan 2004
    Aaahh thought so. Just wanted to be sure. Cheers for that
    Aug 2011
    Chicago
    Zeroed Odometer
    Recently replaced my battery, prior to reading Smart money artcile on pg. 98 of Motorcyclist Magazine, my odometer has zeroed out indicating no milage, is there a recall on 2004 rsv1000r factory or a way to resolve this issue?
    Aug 2011
    Your sisters room
    Amauri stated that "anytime he replaced a battery on a 04-09 RSV in the past, he would adj the clock and RPM light"...
    So my question to this is, why does the Redline light/RPM light need to be adjusted? Is this something that MUST be done? Also, how is this done?
    apriliaforum newb chandler614's Avatar
    Oct 2011
    Lincolnshire
    battery replacement
    I have an 04 RSV1000r factory and the battery is going flat and will need to be replaced, is there a way of doing this without my odometer resetting?
    Jul 2007
    Netherlands
    Quote Originally Posted by rsv1000rfac View Post
    No recall, only solution is to install a later modelyear dash.
    Jan 2012
    Saint Neots, U.K.
    I have a 2004 RSVR that also went to Zero miles. Turns out that this happens if you disconnect the battery with the ignition key in. Take it out before you disconnect the battery and it should be OK. Mine is. Confirmed this just after it happened by deliberately disconnecting after I'd put a few more miles on. Sure enough, key in, battery disconnected, zero miles.
