Page 1 of 3 123 LastLast
Results 1 to 15 of 36
Thread: Exhaust valve servo-motor eliminator needed ?
    Aug 2010
    Denmark
    Hi all,
    I've installed a full exhaust system, and removed the exhaust valve servo motor.
    Now I've got a warning light in the instrument, and I would like to remove it.
    My question is - is it needed to install a eliminator in the valve servo motor electrical connector ?
    Dorsoduro 900
    Westminster, CA - USA
    I've just read thru all six pages and 81 posts on this thread, I still can't believe there is so much confusion about the servo motor and exhaust header flapper valve.
    A few people who posted got it right, but for the most part this thread is very confusing and full of wrong info.
    This is an important topic and I would like to start over to set the record straight.
    I've soft deleted every post after the OP's first post and would appreciate some cooperation in staying on topic with correct info.
    I'll start off with the facts:
    1-) If you install a Race ECU, you can remove the servo motor and cables without the ECU posting any errors whatsoever.
    2-) If you leave the servo in place and it malfunctions, you will get an error code even with a Race ECU installed.
    3-) Without a Race ECU, you can remove the cables but you must leave the servo in place and connected
    4-) If you remove the cables but leave the servo in place, and you replace or update the dash, you may have servo related errors (the dash controls the servo, not the ECU)
    5-) With a Race ECU installed, removing the cables but leaving the servo motor in place is foolish, get rid of it.
    If you remove the cables, don't forget to wire the flapper valve open.
    Though the valve is spring loaded to stay open with the cables removed, they have been known to partially close when under full throttle high engine load conditions.
    And to answer the OP's question:
    No you don't need a servo motor eliminator device if you install a full system without a Race ECU..
    Just remove the cables but leave the servo in place and electrically connected.
    apriliaforum Junkie Destruktor77's Avatar
    Nov 2012
    Jersey, Channel Islands
    This is what i've done, i left it in place with the connectors done up so it didn't get all gunked up and dirty. Is there any issues with leaving it there? apart from the fact it's literally useless.
    XVTuner Cable in Jersey, CI.
    2013 RSV4R - Road
    2008 SXV 450 - Pending Long Term tidy up/restore.
    2006 KTM SMR 450 - HillClimb/Trackday
    Apr 2017
    Bedfordshire
    I did no3 and lock wired it open for now till I get Gabro ecu done
    apriliaforum prov-nov Prospek's Avatar
    Oct 2016
    GVRD Canada
    How about leaving the cables and servo motor in place with the Race ECU, does it function like normal??
    Oct 2015
    Tasmania
    Quote Originally Posted by Prospek View Post
    It does not function as the Stock ECU uses it; if that's what you mean.
    The Race ECU leaves it closed until you put the bike in gear then it opens, that's about the extent of it.
    Caveat being post #2 number 2.
    Oct 2016
    Brea
    Now this is a clear and great info on the subject matter that one can understand . Thx
    Nov 2012
    England
    I know this thread is a little old but just to confirm. If you fit a full system and get ecu flashed can you then remove the servo?
    Oct 2015
    Tasmania
    Quote Originally Posted by 180ade View Post
    If the ECU is flashed to Race ECU & shows Race on dash, yes servo can be removed.
    Nov 2012
    England
    Plan to get stock ecu reflashed so would assume it will display race.
    Not always the case.
    As I recall, some third party ECU flashes like Rexxer do not show "race" on the dash and requires that the servo and Lambda remain connected.
    Oct 2015
    netherlands
    Sorry to bump this threat, but I've got a question.
    Is this only with the Race ecu, flashed ECU or STOCK ecu?
    As I bought a RSV4 2 weeks ago, which has exactly what you describe.
    How would that valve work otherwise ?
    Oct 2015
    Tasmania
    Quote Originally Posted by MrSlashzz View Post
    From MY 2015 RR/RF WSM
    Butterfly valve in exhaust, Stock ECU operation.
    Function:
    It is used to reduce exhaust noise. The exhaust butterfly valve is managed as follows:
    • With engine off: open by 75% • With engine running: regardless of the gear engaged, below 5,500 rpm and below 14 of throttle opening it is fully closed; over 6,500 rpm or 16 of throttle opening it is fully open; under any other condition it is in an intermediate position. With bike stopped and in neutral the valve stays closed, regardless of rpm
    Oct 2015
    netherlands
    Butterfly valve in exhaust, Stock ECU opereation.
    Function:
    So what you say is, whenever I put my bike in gear while standing still without throttling the valve should stay closed ?
    Thats not the case in my scenario, when I put my bike in first gear it opens the valve. the sounds is much more different then when its in neutral.
    Jun 2012
    Ireland
    Didn't the earlier V4 bikes open she put into 1st gear even while stopped?
    This changed at a later stage maybe?
