Results 1 to 11 of 11
Thread: sprocket size. 15,16,17 fron & 40,45 rear
    apriliaforum expert hagasn's Avatar
    Feb 2005
    orlando
    aloha, with over 20k on my bike it's almost time to replace my chain and sprockets. from the following sprocket sizes what would yall suggest? i know the popular change is 16/44 BUT i found a great price and a 44 rear is not an option. i have read a number of threads on this topic and don't plan on riding wheelie's for days or entering the daytona 200. the site claims 16/40 is stock? anyways these are the choices 15,16,17 front and 40,45 rear. what do you think? thanks in advance and ride safe.
    2007 factory evolutione air filter, map 2, tigcraft mid pipes, shortened akrapovic mufflers. 38K and just 4 stators
    apriliaforum prov-nov Dynamo750's Avatar
    Aug 2008
    Edinburgh
    If the bike is 04> stock is 16/40
    On other forums the most common is 15/40
    1 off the front is almost the same as 2 on the back
    Putting a 44 on the back must make the chain too small surely my 42 only just made it
    I feel 15/40 or 16/42 is fine for the road but im going to go 15/42 for my next trackday to try it out
    If you ride on top of the rev tree then higher ratio's will suit you better but if you ride on the torque 15/40 would be fine
    Its got 2 heads and its got a 2 headed monster riding her
    apriliaforum expert Jaguar's Avatar
    Nov 2007
    Melbourne, Australia
    I ran 15/40 throughout the life of my first chain/sprockets (i.e. just swapped the front for a 15) and that was much better than the stock 16/40. In fact, I decided it was about right - but was advised to achieve the same thing by going 16/43 when I bought a new chain/sprocket set. Theory being a smaller front stresses the chain more. I think any effect is pretty marginal though, as I got 20,000km or so from my first chain, having changed the front at 3,000km.
    You can work out what equals what simply by dividing the number of teeth on the front into number on the back to get a ratio. The larger the number that results, the lower the gearing (i.e. the higher the revs for a given road speed). Divide one ratio into another to get the % change in gearing.
    Thus, 16/40 = 2.5 15/40 = 2.67. 2.67/2.5 = 1.067. Thus, you lower the gearing by 6.7% by changing to a 15 tooth front.
    You'll find that this is equivalent to about 2 1/2 extra teeth on the rear - thus, 16/42 is a little higher geared than 15/40 and 16/43 is slightly lower.
    Given your available sizes at the good price, I"d go 15/40. 17/45 would give a similar ratio, but there's a fair chance the standard chain would be too short.
    The Garage:
    2014 RSV4 Factory.
    1989 Porsche 944 Turbo (variable boost, track suspension, 928 discs, Carrera Cup 2 rims, etc - my track day toy)
    2010 Commodore SSV
    Previous Aprilias: 2010 RSV4 Factory (Killed by SUV). 2006 RSVR Factory (sold). 2003 RSV (sold)
    apriliaforum expert JAndrewG's Avatar
    Nov 2008
    Silverdale WA
    Jaguar is exactly right. It's simple math, and it works.
    As he did, I ran 15/40 (-1 on the countershaft) initially, then went to 16/42 when I changed my wheels and had to buy a rear sprocket anyway. The latter is only slightly taller than before as the math suggests.
    In real numbers then, my RPM went from about 3750 at an indicated 70 mph to about 4000 at the same speed, exactly 6.7% more.
    Oh, and the stock length chain works with either of the above combos, 15/40 puts you farther back on the adjustment than stock (longer wheelbase), and 16/42 farther forward (shorter wheelbase).
    Akrapovic full system, NERA top triple clamp, Aprilia accessory rear sets, AF1 Ti bolt kit, etc. etc...
    2007 Ducati GT 1000, red
    Feb 2005
    orlando
    thanks for the advice.the aprilia forum ROCKS! ride safe
    apriliaforum expert wrx_02's Avatar
    Nov 2008
    Fort Worth Texas
    http://www.gearingcommander.com/
    Punch in the gears you are thinking about and it will give you RPMs for each gear etc etc.
    I run a 15/42 on the street right now. I really like it as it is much easier in town and doesn't bog the motor so much.
    I run a 15/44 on the track, wouldn't recommend it for the street as 1st gear is useless thus this is why I use it on the track.
    CMRA
    Sidi Boots
    Motonation
    Vesrah Brakes
    BD Racing
    Dunlop
    Race Tire Services
    Lucas Oil
    Vortex Racing
    Shorai Batteries
    North Texas Superbikes
    1964 Vespa:
    133c/4spd conversion
    2008 Yamaha R6 #728
    apriliaforum Junkie mcjongs's Avatar
    Jul 2005
    Norway, 90 km west of Oslo
    Hi gays...
    All you need to know is here:
    Play with different figures for front&rear sprockets and you will se the diffrences in rpms and speed.
    I use 15/42 and it is much more flexible to pick up speed on 5th and 6th.
    mcjongs
    Attached Files Attached Files
    Stupide videos;http://www.youtube.com/user/Monkeylonkey?feature=plcp
    Bikes right now;
    2008 RSV Factory, Dark Lion
    2004 KTM 450/525-EXC
    2007 KTM 450-EXC
    1980 Yamaha XT500
    apriliaforum expert EA126405's Avatar
    Nov 2007
    Corn Country
    Quote Originally Posted by mcjongs View Post
    Hi gays...
    mcjongs
    mc, sounds like a logical conclusion (I'm to lazy to do the math, but follow the line of thought closely). My question to you is, how/where do you ride? I was planning to go -1 on the front. I'm don't normally spend much time in 5/6th. If that was the case with your riding style, would you still change front and back?
    Feb 2017
    Kuala lumpur
    Sprocket size 16/43 with xring chain 520
    Quote Originally Posted by Jaguar View Post
    What do you think about the size 16/43 with 520 chain? Any review about that? Thank you.
    apriliaforum expert steelman_2's Avatar
    Sep 2012
    Finland
    Quote Originally Posted by zulheikal View Post
    I've ridden with 16/44 520 set for three last summer, I look after those ( I wipe and lubricate those every 100 miles) so now after round 8 k miles those are as best, have loosened the early 'tightness' and are very SMOOTH !
    I'm a (triathlo)nist, that's why I've joined A(prilia) & A(udi) club.
    Mar 2016
    down south
    Also, kind of depends on how you use your bike. I ride a long way to get to the mountains, about 250 miles. If I'm in a hurry to get there or back home I ride interstate. The stock gearing on my 2008 Tuono is great for high speed interstate but, when in the mountains, lower is better.
    You could try 15/40 and see how you like it. Since you already have 16/40, maybe pick up a 15 and try it while the chain and the 40 rear you have on now still have some life left. Someone on the forum may have a used 15 that you could get cheap.
    As far as wear is concerned, I have wondered if going larger on both ends will increase longevity. I've never run across a definite answer to that question. The main thing is to get the best possible quality chain and sprockets if longevity is a concern. A cheap chain is definitely a false economy. And be sure to maintain them.
