Results 16 to 30 of 32
Thread: How to guide: crankcase reseal
    Dec 2010
    FOREST, VA
    re-realing question
    I use a small acid brush and paint it on lightly on both sides.
    Are the mating surfaces of the two crankcase halves the only place the sealant is applied?
    I have seen some posts about decking the heads or lapping the heads. Is sealant applied anywhere on the head or crankcase mating surfaces or once the heads are flat, are the gaskets sufficient?
    This post is directed at all who have opinions, not just amauri.
    Thanks.
    apriliaforum Member i-Zapp's Avatar
    Mar 2010
    NE Ohio
    ok, i've emailed steve the PDF file. expect he'll post a reply with the link once he uploads it. i also added some additional wisdom from others on this thread.
    Tuono 1000R * * * Honda CRF450 mx/supermoto * * * SXV 550
    "The key to life is to die young. And to delay it as long as possible."
    Racing SERVICE Competition Steve / AF1 Racing's Avatar
    New Braunfels, Texas USA
    Quote Originally Posted by i-Zapp View Post
    Linked here:
    http://www.af1racing.com/store/ProdI...v%20reseal.pdf
    Thanks again to i-Zapp. This will doubtless be consulted many, many, times.
    699 W San Antonio St
    New Braunfels, TX 78130
    direct:830-626-3966 fax:830-626-3969
    Currently:
    '97 RS125 Two Stroke
    Previously:
    '00.5 Mille & '97 RS250.
    Feb 2011
    Southern Cal
    Thanks i-Zapp you have lifted the veil of remorse for purchasing a 07 RXV 450
    apriliaforum Member Paizan's Avatar
    Vegas Baby!!
    Awesome i-Zapp. I wish I had your little tips 2 months ago. I took everything apart per the service manual. Got to the Primary gear and before I took it off, saw this thread and didn't have to. (Yes, been disasembleing for 2 months, I work too much) I do have some questions but I am going to post those in another thread as to not clutter this up. Excellent job! I can always count on this forum to get my answers.
    In fact, if given the option of listening to my dealer tech or anyone on Apriliaforum, it's a no brainer. This place rules!!
    apriliaforum prov-nov colo_rider's Avatar
    Aug 2006
    Colorado
    This is absolutely great. I now know why my dealer is not so eager to work on my RXV450 before getting Aprilia warrantee approval. And if they don't do it, I may have to. So, once again the power of this forum shows. Thanks!
    '09 Tuono Factory, '03 Tuono, '03 BMW R1150GS
    apriliaforum prov-nov Darth Vader's Avatar
    Aug 2011
    Zagreb, Croatia
    Before resealing housings, it is desirable to check and prepare the sealing surfaces. If the sealing surface is not flat enough, problem will come back sooner or later.... After many resealed Aprilias I found that the proper flattening is one of the crucial facts of the successful fixing oil-water mixing issue. For that purpose, I’m using 500x350x45 mm grinded cast iron plate and coarse grinding paste. That procedure fixing small irregularity on the surfaces...Similar procedure has been described in a factory warranty claim.
    Pictures showing surfaces after described procedure... I done it today on one burned engine...
    Most critical, and cause of the oil-water mixing is triangle area between cylinders...Of course cylinders and housings have to be preassembled and grinded together...
    Aug 2011
    st. helens
    Good pictures darth vader, just to add if you havent got use of a cast iron grinding plate you can use 8mm guage or thicker pane of glass available from most glass makers/cutters outlets
    Aug 2011
    Zagreb, Croatia
    Quote Originally Posted by mechcanico lee View Post
    Thanks, and beside mine Motorcycle Mechanic trade, I'm also a Toolmaker, so I prefer iron
    Sep 2011
    United States
    same topic. What would you guys think my motor needs? i have an 08 sxv 550 6k miles and runs fine valve clearance has been ck, but do i really need to break it down? is the motor guna granade? thanks for your advise
    Aug 2011
    Zagreb, Croatia
    Quote Originally Posted by Sneaky Aprilia View Post
    simply,
    if it isn't faulty, don't fix it ...
    but pay attention on well known oil-water issue
    apriliaforum prov-nov Thund3r's Avatar
    Oct 2008
    Norway
    Threebond 1207D
    Will this sealant work?
    Aprilia SXV 550 2007
    Aprilia RS 250 1995
    Aug 2011
    Zagreb, Croatia
    Quote Originally Posted by Thund3r View Post
    Threebond 1207D
    I am useing this one
    http://www.techsilonline.com/getatta...Tech-Data.aspx
    it is recommended by Aprilia, and I can say it is the best I have ever tried... Keep it in the fridge...
    Oct 2011
    Alabama
    Reverse Seal
    Nice work.
    If it is a motor whose history is known to you (like your own bike), this is a very good how-to. The only thing I would add is that further disassembly may be required on a older higher mileage motor.
    Regardless if antifreeze has mixed with the oil, I always replace the rod bearings. Especially on the pre-09 motors that had the stator cover oil seal installed backwards by the factory (that seal feeds oil pressure to the rods) bulletin #008-2008.
    I also chk the valves for wear, inspect the oil pump (especially the 12mm idler gear shaft pressed in the crankcase), chk clutch basket and hone the crankcase mating surfaces.
    Yesterday I took delivery of a new '08 SXV. Before deciding to buy I spent a fair amount of time and effort in research and asking questions and concluded that the '08 was clear of issues (ex: orange sealant). I may not have spent enough time though because I missed this "reverse seal" issue.
    I have not yet started this motor...should i correct the seal before doing so? Can this be done without major engine disassembly? Are there other issues that I should be aware of? Thanks!
    NORTH America
    Nice work.
    Is there a specific(upgraded/better) bearing's to be used as a replacement?
    PRESENT
    07 SXV 550
    08 510 SMR Husky(street & track)
    08 ZX10 (Race/track bike)
    07 Speed Triple (Street)
    05 R1 (Street & selling)
    04 YFZ 450 (Strictly dirt)
    03 KX 250 (son's dirt bike)
    PAST
    Way to many to list.
