Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: How to guide: crankcase reseal
    apriliaforum Member i-Zapp's Avatar
    Mar 2010
    NE Ohio
    The first time through this job was a lengthy ordeal, due to my unfamiliarity with the engine and poor Aprilia documentation. There's quite a few posts on this forum that explain in various detail how to accomplish the job, but as far as i can tell, nothing in a convenient collection.
    So, having to perform the job a SECOND time (dont ask!), i decided to pay it forward and assemble a guide that's meant to SUPPLEMENT the Aprilia service manual. It's meant to just add clarification and tips.
    The entire job took me 6 hours, and i honestly believe that anyone who's serviced the internals of a motorcycle engine should have no problem with it.
    (flickr link removed)
    In .pdf format here:
    http://www.af1racing.com/store/ProdI...v%20reseal.pdf
    Tuono 1000R * * * Honda CRF450 mx/supermoto * * * SXV 550
    "The key to life is to die young. And to delay it as long as possible."
    Nice work.
    If it is a motor whose history is known to you (like your own bike), this is a very good how-to. The only thing I would add is that further disassembly may be required on a older higher mileage motor.
    Regardless if antifreeze has mixed with the oil, I always replace the rod bearings. Especially on the pre-09 motors that had the stator cover oil seal installed backwards by the factory (that seal feeds oil pressure to the rods) bulletin #008-2008.
    I also chk the valves for wear, inspect the oil pump (especially the 12mm idler gear shaft pressed in the crankcase), chk clutch basket and hone the crankcase mating surfaces.
    apriliaforum prov-nov gromm415's Avatar
    Mar 2010
    west marin
    that is so cool! i always wondered what it looked like on the inside. thanks for taking the time to put that together.
    apriliaforum expert kimzx1000r's Avatar
    Sep 2007
    Illinois
    Nice documentation. Thanks....
    apriliaforum expert ETN550's Avatar
    Sep 2008
    Nice work.
    I rebuilt an '07 motor and put the new crank seal in "backwards" the way Aprilia had it. Is it ok to use same seal part number and just flip it around on '07 - 08 ?
    The old original seal has been superceded by the new p/n #855031.
    The bulletin says not to install the old p/n seal in the correct direction (as most of us would think).
    Always use the new p/n and install it in the direction shown in the photo.
    apriliaforum expert soyrico's Avatar
    Sep 2007
    Hollister California
    Good job!
    One frequent question that comes up about applying sealant to the case halves is how to apply it and where. If you have pic's I think it would be helpful (The "V"). I apply it to one side but I never think about taking pictures during that step because I want to get it sealed quickly.
    “A man who dares to waste one hour of time has not discovered the value of life.” - Charles Darwin
    http://www.panoramio.com/user/249951
    http://www.panoramio.com/photo/6895299
    Baja junkie for life
    2007 RXV 4.5
    apriliaforum expert Markee's Avatar
    Feb 2008
    Melbourne, Australia
    Good work. This would be great as a sticky, what with Amauri's input as well it makes doing the work yourself a lot less daunting.
    www.supermotoaus.com APRILIASXV550
    Quote Originally Posted by Alice Racing View Post
    The motor and maps are race orientated, and want gunning !!
    www.moto-extremes.com
    Quote Originally Posted by soyrico View Post
    Good job!
    I use a small acid brush and paint it on lightly on both sides.
    Racing SERVICE Competition Steve / AF1 Racing's Avatar
    New Braunfels, Texas USA
    If there are no objections, I will make this a sticky...
    699 W San Antonio St
    New Braunfels, TX 78130
    direct:830-626-3966 fax:830-626-3969
    Currently:
    '97 RS125 Two Stroke
    Previously:
    '00.5 Mille & '97 RS250.
    Mar 2010
    NE Ohio
    ... the only suggestion i have is that the images be moved/copied to this server to insure their availability long term. i can convert the whole thing into a single PDF file and upload it, but i think i will need more than the 244kb limit for that file.
    apriliaforum expert duc slayer's Avatar
    ny
    #1 Forum Mod Pisser-Offer
    Some say a comet will fall from the sky. Followed by meteor showers and tidal waves. Followed by faultlines that cannot sit still. Followed by millions of dumbfounded dipshits. Some say the end is near. Some say we'll see armageddon soon. I certainly hope we will
    I sure could use a vacation from this stupid shit, silly shit, stupid shit... One great big festering neon distraction, I've a suggestion to keep you all occupied. Learn to swim!!!
    Quote Originally Posted by i-Zapp View Post
    another good idea
    If you're comfortable with it, you can email the oversize .pdf to me (steveataf1racingdotcom) and I can upload it to our server, and link to it in this thread.
    Currently:
    Previously:
    Feb 2009
    Tri-Cities, Washington
    Converted it Sunday for my own use! File size ended up being just under 4M with the large images.
    Also... instead of creating another sticky, why not just add this to the existing "How to" thread?
