I HAVE searched and reviewed a dozen threads on T/B Synch but I would like to confirm how much strip down is required on my 06 Capo.
I recently did a 32,000 mile major service including valve check (all in spec!), oil change, air filter, spark plugs, etc. Next is T/B Synch & TPS check.
From what I have read I need only to remove the left lower panel to access the service hoses and connect them to my Motion Pro mercury stick. I also have a Twin Max digital balancer which I may try as well. I have used both devices on several previous machines. So I don't need to lift the tank? Or airbox?
After the T/B balance I plan to connect my Centurion Pro Europe, check the TPS and reset if necessary.
Welcome all comments and tips. Thanks, Stuart
), Bags Connection tank bag
