Fun warning from Aprilia:
DO NOT SPEED RECKLESSLY. THE
VEHICLE GRIP ON THE ROAD IS SUB-
JECT TO LAWS OF PHYSICS WHICH
EVEN THE ATC SYSTEM CAN NOT
ELIMINATE.
And now a real question relating to the APRC system. The OM states:
IF THE VEHICLE IS FITTED WITH
TYRES OTHER THAN THOSE INDICA-
TED IN THIS USE AND MAINTENANCE
MANUAL, THE LEVEL SETTINGS OF
THE SYSTEM MAY NEED TO BE
MODIFIED IN ORDER TO OBTAIN THE
SAME BEHAVIOUR AS BEFORE.
So i presume if you make ride-height changes you'd also have to do this? How is it done?
