I changed my standard shock as most have done, but I never measured the unsprung height of the bike before changing it.
I was wondering what the distance is between rear wheel axle centre to the centre of the rear brab rail side bolts..
Mine measures 600mm when bike is held staight up with no load other than the bike itself, my front is 4.5 rings showing.
I feel the bike is really easy to turn into corners but is unstable or twitchy when in the corner.
the rear shock is a Mille 2000 I recall, has yellow spring, I also fitted the triangle levers that came with it.
Interested to see what others measure to see if mine is different? any thoughts would be great..
