Page 40 of 54 FirstFirst ... 30383940414250 ... LastLast
Results 586 to 600 of 807
Thread: TuneEcu, Free injection mapping and diagnostic for Caponord/Futura.
  1. #586
    Morgan Territory, CA
    Quote Originally Posted by Britt View Post
    Thank you to those of you that have worked so hard to provide such a great tool, great instructions, and for the custom maps!
    I've got my cable and have used TuneECU to update the factory map on my bike to the newest version. I did try the Catfish map and had a very uneven idle so I reverted back to OEM. I assume I need to check and adjust my CO at idle.
    Local mechanics around me are not interested in letting me tune while they sniff my exhaust, so I wonder if I have options other than ordering a Gastester from Europe. I suppose I could buy one and re-sell it when I'm satisfied with my tune.
    My question is - how do you regular guys like me check their CO? Do you have relationships with mechanics that own a tester, or are you all buying Gastesters?
    If you want to try my maps, then you need to adjust the LTFT & IFT as I outline on my maps page to get good results. My map needs a more positive or larger IFT setting than the oem map for the idle mixture to measure the same exhaust CO.
    Find a performance tuning shop with a dyno & 4 or 5-gas exhaust analyzer. Ask then for a exhaust sniff at idle while you adjust IFT. I doubt they will turn down your money.
    Some owners can adjust IFT roughly by ear. Adjust IFT up & down to find where the LEAN rough idle IFT setting starts and where the RICH rough idle IFT setting starts. Should have a good idle between these values. Re-set the IFT to 1/3 the difference of these IFT values, added to the lean IFT value. So, if lean is at IFT of +10 and the rich is at IFT of +30 for example, then set the IFT to ((30-10) * 0.333) + 10 = ~17.
    Good luck,
    Catfish ...
  2. #587
    apriliaforum Junkie Britt's Avatar
    Westmont, IL. USA
    Thanks for taking the time to type up those details Catfish. My issue is that I've contacted several shops in the area and none of them are interested in my money so far....
    2002 Aprilia ETV1000 Caponord
    http://britt-motorcycling.blogspot.com/
  3. #588
    apriliaforum prov-nov Cichal's Avatar
    Sep 2008
    London
  4. #589
    Durham, United Kingdom
    I tried downloading one of your maps today (as they seem to be the best about) but the green light on the tuneecu flashed, and flashed and flashed! left it for about 4 hours and still flashing, any ideas?
    Good luck,
    Catfish ...
  5. #590
    Jul 2008
    Richmond, Ca. USA
    Quote Originally Posted by Cichal View Post
    that's convenient.
    Dadsafrantic
    2006, center stand, mra wind screen lip thingy, givi top case, fuel lines done, catfish 428 map, freeway commuter
    ATGATT
    69500 miles 5/1/13
  6. #591
    apriliaforum Junkie nerald's Avatar
    Dec 2007
    Cumbria
    Quote Originally Posted by john.storey View Post
    Using tuneECU to download a map to the bike, you should get a green bar at the top of the screen, this will fill up as it downloads the map to the ECU. The green flashing light you mention is tuneECU's way of letting you know that comms between the ECU and PC are healthy. (some data will be passing between the two such as air temperature voltages etc this is why it will flash almost constantly when connected)
    08 ETV 1000 Caponord
    Multistrada 1200
  7. #592
    John,
    READ the links I referred you to in your other thread. You need to follow the download procedures EXACTLY as stated. From what you are writing in 3 different threads, it appears to me that you are skipping half the steps. That will never work correctly.
    READ & understand BEFORE attempting any downloads.
    Good luck,
    Catfish ...
  8. #593
    apriliaforum Junkie SoCalSV's Avatar
    Feb 2011
    Gainesville, TX
    Gah - expensive for a bit of soldering and heatshrink! holy crap who would pay that?!
    pdfffft - I was gonna buy one, it looks like he sold the 3 he made :S yeah, yeah.....I'm that lazy anymore
    I don’t need to trek through Africa and I don’t need to climb Everest — I need to ride every f***ing curvy road between here and there. That’s far more powerful. Far more majestic. Far more of a journey.
  9. #594
    apriliaforum Member knobblywobbly's Avatar
    May 2011
    Crewe, UK
    How much is the fish?
  10. #595
    apriliaforum Junkie anssi's Avatar
    Feb 2004
    Helsinki, Finland
    If you want to build the cable yourself, I have some leftover bike-side connectors (just the white plastic part with 6 metal pins). I can send them for 8 € (with Paypal).
    RST 1000 Futura '03/04 darkness black
    Staintunes,
    Bef's license plate relocator, aftermarket rectifier, Scottoiler, YTZ14S battery, Bagster tank cover + bag, metal QD L-part, Fren Tubo Carbotech break lines, Autocom, Garmin Zümo 660, Acumen DGV gear+voltage indicator, derestricted airbox
  11. #596
    Sep 2008
    London
    Hi catfish,may I change the rpm value(see http://img545.imageshack.us/img545/4784/capo.png) between 64 and 90 C* to 1450?My idle is quite erratically now.
  12. #597
    The idle speed vs. temperature table in my map is NOT the cause of your rough idle. Yes, you can raise the idle speed with those table values, but I do not recommend that. You need to find the real cause of your idle problem & fix that.
    What does "My idle is quite erratically now" mean in detail? A bad idle that nearly dies is usually a vacuum leak in the hoses near the throttle bodies.
    Good luck,
    Catfish ...
  13. #598
    Sep 2008
    London
    When the engine is warm,rpm's flying between 1320 and 1410 on neutral.I cleaned IDLE AIR CONTROL VALVE three weeks ago.
  14. #599
    Jun 2010
    Netherlands - Türkiye
    your bike is lean or rich, put a gastester on it and adjust the IFT when the engine is WARM
    01 Futura [infinity blue]
  15. #600
    Sep 2008
    London
    http://www.apriliaforum.com/forums/s...TuneEdit/page5
    post"62"
