Page 2 of 55 FirstFirst 12341252 ... LastLast
Results 16 to 30 of 811
Thread: TuneEcu, Free injection mapping and diagnostic for Caponord/Futura.
    apriliaforum expert moto-abruzzo's Avatar
    Somewhere down the road...
    Acknowledgement
    Well, a big thank you to Alaine and Crenninger for bringing this piece of software to us - an early Christmas present indeed! Cheers gents ... I'll be raising a glass to you this evening!
    Test Run
    Ok, so after breakfast I was out in the garage like a shot ... on the Tuneboy cable drivers it hooked up to the ECU and never dropped connection over the couple of hours I was playing.
    All in all I tested any and all functions I could - and ran it back-to-back against Tuneboy/Edit. I generated fault codes, loaded, edited and downloaded maps and the bottom line is, it worked. It never crashed, locked or lost comms.
    The only questionable difference I came on was the Rev Limit and Thermo Fan settings ... in TuneBoy they are far more detailed ......
    Name:  rev limit-TuneBoy.jpg
Size:  81.0 KB Name:  Thermo Fan - TuneBoy.jpg
    In Tune ECU, much less detailed.
    Name:  rev limit - TuneECU.jpg
    However, Alaine must have code in place to make sure the 'missing' data fields match the one you can change. On changing the rev limit up to 10,000rpm and fan temp down to 104C In TuneECU, everything looks fine when opened in TuneEDIT. So in the end ... Keep-it-simple works!
    For those used to looking at TuneEDIT maps, TuneECU might be a bit like riding an old Brit bike (gears & brake swapped) after getting used to 'modern' stuff .... ok, but a bit odd till you get used to it! The X and Y axes of the graphs are swapped over and I found it took a while to get my head around the map layout - mind you, the addition of colour is a fantastic tool for spotting rogue data in the map!
    At the end of the day, it does what we want, very well.
    03 Rally-Raid, 08 dogs, 05 cats, 09 chickens, 08 Kestrel ....and a goat declared SORN
    apriliaforum expert nav18tor's Avatar
    North Essex, UK
    I wish I had ordered the cables and connectors earlier
    Anybody else in the South East of the UK are welcome to use mine once I have made them up
    Have a warm dry double garage if you need some indoor space
    He who dies with the most toys wins
    Crispy X Caponord - Burned Grey - replaced with Ducati Multistrada 1000DS - Black but not crispy but now sold, Honda Transalp XL700V-8 lasted two weeks before I got bored, so got an 07 Yamaha TDM900 but then swopped it for a Yamaha FJR1300 in faster blue
    Touring Portugal? this will be a perfect base for motorcycles
    http://www.pureholidayhomes.com/coim...al-p32294.html
    apriliaforum expert 2pist's Avatar
    Utah
    Radio shack sells the 6 pin molex connector for a whopping $2.59 It's available in store..
    http://www.radioshack.com/product/in...ductId=2062448
    01 RSV, Micron TI w/TI chip
    06 Triumph Sprint ST
    01 YZ 250
    Jul 2008
    Richmond, Ca. USA
    wahooo
    just let me say that again...wahooo!
    Dadsafrantic
    2006, center stand, mra wind screen lip thingy, givi top case, fuel lines done, catfish 428 map, freeway commuter
    ATGATT
    69500 miles 5/1/13
    apriliaforum Junkie GH_services's Avatar
    Aug 2010
    watford, herts
    yeah - works like a champ!!
    small issue though, i have an old panasonic toughbook for doing my garage work and its screen is 800 x 600 - apart from changing the screen resolution in the control panel and missing parts of my desktop screen - is there any other way round this?
    I don't think so .... it defaults to 1024x600 for notebooks ... only while in map-edit mode can it be resized to full-screen.
    800x600 is pretty small!
    Nov 2009
    Redwood City, CA - USA
    Quote Originally Posted by GH_services View Post
    no, the minimum is 1024x600 (for netbook) and honestly, you need at least that to be able to read the numbers.
    Sorry :-)... get an external monitor or something.
    Nov 2009
    Quote Originally Posted by 2pist View Post
    did you buy it and confirm it works?
    I have a radio shack close by, I'll check it out this week.
    Nov 2009
    Quote Originally Posted by moto-abruzzo View Post
    Acknowledgement
    Test Run
    Checking on the RPM settings.
    Nov 2009
    Quote Originally Posted by RobC View Post
    one question Christian, are the wiring diagram pinouts looking at the solder side of the plug or the pin side? As you know I no longer have the Aprilia OBD connector to check whether they're marked with pin numbers.
    Bob
    It's looking at the outside plug/pin exposed connectors.
    Nov 2009
    Quote Originally Posted by ELMOSISU View Post
    I have a technical issue. I had previously loaded Tuneboy and the cable driver on my laptop. I seem to be unable to get the cable to recognize the recommended driver from Alain's site ( CDM 2.06.00 WHQL Certified). I removed all of the Tuneboy program items, and the cable still does not ask to look for a driver. I try and do it manually, and it does not recognise to downloaded driver file as a driver. My computer skills are limited. Do you have any recomendations?
    Make sure you are not connected to the internet.
    In Windows 7 / vista and sometime XP, windows would go on it's own to find the right driver for you online.
    So make sure you disconnect any Wifi and unplug your ethernet cable, then Windows will ask where to locate the driver.
    but if you are using a tuneboy cable, you can re-use the tuneboy driver.
    What happens is Tuneboy "rename" their cable from FTDI generic to TuneBoy cable.
    Funny thing I renamed my generic to Tuneboy USB... hopeing to make the Tuneboy work... it didn't.
    Moto-Abruzzo confirmed that you can use the tuneboy driver, as a matter of fact, TuneECU and tuneboy as of now are using the same driver version.
    Christian
    Nov 2009
    I got the Tuneboy cable driver re installed. I will see if it works later today.
    Christian........ I will send you a screen shot of my stock map.
    screen shot are useless, you can save the map you read from the ECU in the .hex file format, you can email me this.
    apriliaforum expert ELMOSISU's Avatar
    Oct 2006
    Cottage Grove, OR
    Quote Originally Posted by crenninger View Post
    I got things up and running with some questions.
    Below are 2screen shots of the Test, and Map Edit tabs of the program. The Diagnostics works just fine, and give the 4 coils and other info similar to TuneBoy.
    As you can see, I was not able to have a map come up, however I was able to do all of the adjustments that are typical. TPS reset, Long term Idle, Idle CO trim, Stepper adjustment. That part is great!
    I had no disconnects on TuneECU, once I got everything properly running.
    (Tuneboy regularly disconnected, and caused me to reset the connection.)
    I was not able to locate any type of .hex file or a way to pull up my map other than what was in the upper left of the screen on the map tab.
    What is my next move?
    thanks!!
Name:	tuneecu first run no map.jpg
Name:	tuneecu sensors first run.jpg
    2006 Caponord - Rich's custom seat, drilled stock pipes, Catfish "429" map, Braking wave rotors, Rally Raid Bars/fender, Ricor Intiminators, Skidmarx custom windscreen ( propane torch special ), Bags Connection tank bag
    2004 Moto Guzzi Breva 750ie
    Nov 2009
    thanks!!
    click "ECU" / "Read Map" and report back what happens.
    Make sure the green square in the bottom right corner is blinking,
    Red = not connected
    orange - connecting
    green - connected.
    Nov 2009
    Acknowledgement
    Test Run
    I got confirmation,
    in TuneECU you only set 1 value, and the other 3 values are derived from the value you specify.
    -50RPM
    +100RPM
    +200RPM
    In short, set your Cutoff RPM and don't worry about it.
