Page 4 of 87 FirstFirst ... 234561454 ... LastLast
Results 46 to 60 of 1291
Thread: TuneEcu, Free injection mapping and diagnostic for Caponord/Futura.
  1. #46
    apriliaforum expert catfish's Avatar
    Morgan Territory, CA
    Quote Originally Posted by moto-abruzzo View Post
    The latest tunes are:
    050428 if you don't have cat converters (bulges in the exhaust link pipes behind the heat shileds) - or
    050429 if you do have cats.
    050428 and 050429 are both for Caponords with cats & O2 sensor.
    The difference is that 050428 REQUIRES the purge-control valve be connected to the ECU for the charcoal-canister & fuel-vapor recovery plumbing that USA & some other models came with.
    See my map page for the details of all THREE current available maps from Aprilia.
    Catfish ...
  2. #47
    apriliaforum expert ELMOSISU's Avatar
    Oct 2006
    Cottage Grove, OR
    Very good info, guys....... I will give the 429 map a try as per your instructions.
    2006 Caponord - Rich's custom seat, drilled stock pipes, Catfish "429" map, Braking wave rotors, Rally Raid Bars/fender, Ricor Intiminators, Skidmarx custom windscreen ( propane torch special ), Bags Connection tank bag
    2004 Moto Guzzi Breva 750ie
  3. #48
    Nov 2009
    Redwood City, CA - USA
    Quote Originally Posted by ELMOSISU View Post
    BEFORE YOU DO, what do you have in your bike?
    likely you have that one already.
  4. #49
    Quote Originally Posted by nerald View Post
    I think you will have to wait until Catfish has tested TuneECU with his maps 1st before they will be released in this format.
    Quote Originally Posted by crenninger View Post
    Yes, please read this:
    http://www.apriliaforum.com/forums/s...5&postcount=80
    We can convert the maps - but we won't... We'll wait on catfish for that.
    Since its going to be 2-3 weeks before I can start testing TuneECU myself, it maybe Christmas before _I_ get these conversions available on my web pages.
    I have no problem with a TuneECU-knowledgeable person converting my existing maps & making them available for TESTING PURPOSES ONLY at this time. Everyone just needs to realize that I have not used or converted any maps myself yet, so whatever you load into your Caponord did NOT come directly from me. This means that the file COULD be different from what I originally provided. Incorrect values in fuel or ignition maps can DESTROY YOUR MOTOR! Proceed with caution.
    So, good luck & let us know how things go!
    Catfish ...
  5. #50
    Nov 2009
    Quote Originally Posted by catfish View Post
    Catfish ...
    I could do... but who's a layer so they can tell me the proper language to put in my post before I provide the maps :-)))
    catfish, ok with this?
  6. #51
    Yes ... as long as we get to SHOOT the lawyer when you are done with him!
    Catfish ...
  7. #52
    apriliaforum Member Sarctom's Avatar
    Mar 2009
    Slovenia
    I think that in this winter capos will run more often than in the last Nice work!
    And don`t worry about lawyers, capo ovners know when they screw up, and don`t blame others we proudly present all the fulish stuf we made on this forum
    T.
  8. #53
    Jan 2005
    Flashing services
    For some of us that is less than talented I would be willing to pay someone to reflash my ECU after I pull it and mailing it out then back??? BobL.
  9. #54
    Oct 2006
    Cottage Grove, OR
    yes, I have the 429 map already, loaded stock from the factory.
    I was under the impression that I should be able to 'see' a map in the map section of TuneECU, and that now it appears I need to hook it back up to the bike, and load the .hex 429 map?
    Do I need to load the .hex map of the 429 into TuneECU in order to see my current map? ( which should be the same?)
    I'm not sure what I am trying to do other than getting a .hex file to email to you. Just a little confused.
    (BTW. the green light is always flashing in the lower right. the screen shots apparently miss the "on" flashes.)
    At this point, there are no changes that I would want to do until Catfish's map is ready.
Name:	tuneecu map not present.jpg
  10. #55
    Nov 2009
    Follow Moto-Abruzzo instructions step by step.
  11. #56
    Nov 2009
    Originally Posted by 2pist View Post
    Radio shack sells the 6 pin molex connector for a whopping $2.59 It's available in store..
    http://www.radioshack.com/product/in...ductId=2062448
    did you buy it and confirm it works?
    I have a radio shack close by, I'll check it out this week.
    Just bought some, they are the proper connectors.
  12. #57
    apriliaforum prov-nov Tom_Hamburg's Avatar
    Nov 2010
    Germany
    Good day,
    I'm Tom and I am the operator for the homepage www.tuneecu.com
    Your Christian has kindly asked me to visit your page.
    For problems with the software please contact on Alain.
    New Maps, You may send you to me or Alain.
    Sorry for my bad English but I hope you can understand me.
    BR, Tom
    TuneECU
    Triumph Speed Triple 1050, Triumph Rocket Roadster
  13. #58
    Oct 2006
    Cottage Grove, OR
    I missed Moto Abruzzo's clear directions
    sorry guys. you've been patient!!
    see what I was able to do:
Name:	tuneecu screen shot hex 429 map loaded.jpg
  14. #59
    apriliaforum expert 2pist's Avatar
    Utah
    I figured. I don't own a Capo so I couldn't try. I Used the standard molex two pin connectors from radio shack for a pair of turn signals i built and they worked pefect. So, I figured these would too.
    01 RSV, Micron TI w/TI chip
    06 Triumph Sprint ST
    01 YZ 250
  15. #60
    Nov 2009
    Was this read from your ECU or loaded from Hex file
