Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Thread: How To Remove A Thermostat?
    Parker Colorado
    Yeah... you can use the teflon tape and a bunch of it. On the single pin sensor you can't as the threads make the ground for the sensor.
    apriliaforum expert Lorenzo's Avatar
    Jan 2008
    Golden Triangle, Texas
    Found another!
    Just got back from Walmart, and according to the back label it appears that Prestone® Extended Life Antifreeze/Coolant is also Nitrite free / Phosphate free / Borate free / Silicate free.
    Retails for $10/gal+tax, minus $7 mail-in rebate, plus 44¢ 1st-class postage, that's about $4.27/gal, and this is not the 50/50 but the concentrate-type -- not a bad price!
    And thanks, HG!
    apriliaforum Member aurelius's Avatar
    Oct 2005
    Dallas, Texas
    Quote Originally Posted by Lorenzo View Post
    How are you supposed to remove this thermostat which appears to be very tightly fitted?
    How do you access the thermostat housing for removal in the first place? Searched and can't find anything. Any tips appreciated...
    2001 DiTech (Morini) derestricted, Leo V ZX pipe, 7 gr rollers, OE clutch spring.
    2002 DiTech (Morini) derestricted, Leo V ZX chrome
    Oct 2005
    Dallas, Texas
    Ok, thanks for the reply. I see in your photos that you've removed the motor, or at least the cylinder head. Which would obviously make thermostat access a whole lot easier but how would I access those 5mm hex bolts while everything is still assembled? IIRC, the frame is in the way with the inspection covers removed.
