There are no words to describe how good that auto blip is. Now, whats it going to take that to get it on my race bike![]()
2012.5 Aprilia RSV4 Factory APRC Race bike
Maintained and Tuned by Dave @ motoitalia.com.au
Hi Tim, so thats a Motec derived setup. JesussssssThats a bit exy isn't it! I'm in Australia - surely we can get a Motec for a case of beer :P Whos Sven?
Nice - so , ecu, coil modules, wiring harness, dash.... What else ?
Hahahah![]()
2010 RSV4R track bike
K+N Race Filter | CRC Fairings | Apex riser adjustable clipons | AR GP2 Slip-On | 2011 Race Map | Bazzaz TC QS Fz | ASV Shorty Levers| Puig Wind Screen | TechSpec Tank Grips | Gilles Tooling Gear Shifter Support | GB Racing Clutch and engine Covers | Woodcraft rearsets | AIM MXL Pista Dash |
Here is what you need:
ECU (+options)
Dash (SDL is sufficient)
Wiring Harness
Lambda to CAN module or Dual LTC.
Strain gauge QS (or you can make a circuit that gives you a negative and positive output using two regular quickshifters)
Ignition Module (usually either Motec's IGN4 or the Bosch 211 unit)
GPS module or lap beacon receiver and lap beacon (not reqd, but you need it for some of the functionality)
Lan angle sensor (not reqd, but you need it for some of the functionality)
For the ECU, you will probably want to enable some type of logging (you can an unlimited channels at up to 1000Hz with 250MB of space) and upgrade to Pro Analysis which allows better review of data.
And, most importantly, it takes someone like Tim who knows how to set everything up. The ECU setup is way more complicated than the Powercommander. You need to set up everything from down to how you determine timing from the pressure pulses sensed at the throttle bodies and the crankshaft speed sensor.
So, this is not cheap. The good thing is that all the parts pretty much keep their value and can be transfered from bike to bike. Also, this has been a fun project for me. But, I definitely had to ask a fair number of people, including Tim, a lot of questions until I got it right.
On a related note, the IBS Performance team in Denmark was trying to sell a full M1170 setup for the RSV4 a couple of months ago, but I am not sure if they still have it.
Nice, thanks moto2 for the information! I guess if you can come across the parts for alot less than new it could be a worthwhile investment over the APX2. $23k is just simply far far far too much unless you;re the front runner.
Not sure I see the resemblence between that guy (Tim?) and Brad Pitt :P
So have you been running the bike with AFM this season? Don't tell me you were at Sonoma last Friday before the race weekend, I did that PTT track day, didn't see you but it was really crowded. I'd like to see you and that wiring harness in action.
potere - italian for power
have M1 permit, will travel
Dastrix this company in new zealand makes the clutch activated autoblip. Here it is for the r1 not sure if they have it available for other bikes.
http://www.youtube.com/watch?v=VF2FNfAzwdc
http://techtronicsracing.com/
2012 Aprilia RSV4 Factory APRC
BST Carbon Wheels . TTX36 Ohlins . Braketech 220mm Rear Floating Rotor
