Results 1 to 15 of 18
Thread: Connecting rod screw - reuseable?
    apriliaforum Member Torch's Avatar
    Dec 2009
    Sweden
    Just as the title says, are the connecting rod screws reusable?
    Says nothing about this in the engine workshop manual, just the procedure of how to re-torque them.
    What does pros like Allen do?
    Jun 2007
    McMinnville, Oregon
    I have no idea what Aprilia recommends, but I swore off ever reusing them back in my carting days when I tried reusing one and a few miles later had bits of crankcase, connecting rod, and piston sitting in my lap and a huge hole in the crankcase - but that was a looonnngggg time ago and a two-stroke engine.
    Dr Duc
    '06 Ducati PS 1078 LE (Too many mods to list)
    '01 Aprilia SL 1000 (RSV Swingarm, RSV steering damper, Tigcraft 80mm exhaust)
    '04 KTM 200 EXC (for sale)
    '03 Yamaha TT-R125E (with a bunch of BBR mods)
    '98 Yamaha YZ4OOF (seized crank, needs fixin')
    apriliaforum expert cal550b's Avatar
    Dec 2006
    North Yorkshire
    yes they are ,
    Dec 2009
    Sweden
    I see your point DrDuc.... but a twostroker with rod screws?
    What it all comes down to is how the screw joint is designed. If the screws are not stretched past yield strength during torquing, and past fatigue yield strength during operation, then it should not be necessary to replace the screws. But that's theory. I want to hear what the experienced engine builders in here do.
    Thanks cal550!
    apriliaforum expert Mooseknuckles's Avatar
    Jul 2008
    N/A
    fyi Cal IS an experenced engine builder
    apriliaforum expert Allen Noland's Avatar
    Nov 2008
    Mountain Lake Park Maryland, Lima Peru
    Quote Originally Posted by cal550 View Post
    yes they are ,
    ^^^ what he said!
    Noland Trans-World Cycle
    7 East 1st Ave. Mountain Lake Park, MD 21550 * Phone (301) 616-2034 * e-mail allennoland@yahoo.com
    http://www.facebook.com/NolandTransWorldCycle
    Rod bolt school, good article:
    http://www.chevyhiperformance.com/te...nfo/index.html
    When I was working on the race team motors I would re-use the bolts one time and then discard.
    Dec 2009
    Sweden
    Thank you all, you're great!
    (For easier future forum search, here's the part no for Connecting rod screw AP9150127)
    apriliaforum expert Danneh's Avatar
    Sep 2009
    Sweden
    Still on topic:
    What methods do pro's use to torque the rod bolts?
    Aprilia service manual calls for the torque angle method described in the article I linked.
    The most accurate method is to measure bolt strech, but not possible with a bolt that screws into a blind threaded hole.
    Sep 2009
    Sweden
    Thank you amauri, much appriciated!
    As when you first go with the torque wrench to 15Nm then add 48-50 degrees of turning (little more than 1/8 of a full cycle)
    Any good way to measure the 48-50 deg?
    And where to put "Molicote G-N Plus", in threads or on bearings?
    Dec 2009
    Sweden
    Quote Originally Posted by Danneh View Post
    The only time I've heard of the Molykote G-N product (G-N Plus I have never encountered, and I can't find it on Molykotes website) is in nuclear power plant application, where the clamping force of a torqued screw joint connection is extremely important to control. Surprisingly I have seen results showing bolt stretch (As Amauri writes) as a function of applied torque, with an extreme consistency when using Molykote G-N. And when not using Molykote, the actual bolt stretch has varied hugely at a given bolt torque.
    Hence, in a screw connection so important in our engines as the connecting rod screws, I can not enough emphasize the importance of using the recommended Molykote product.
    Perhaps you and me (both from Sweden if someone didn't notice) could make a group buy of Molykote G-N Plus since the price is ridiculous. I will contact my friends at the nearest nuclear power plant maintenance department to see if I can get a free sample... I'll let you know, or you've already got it?
    In other words, use it on the threads, and on the friction surfaces between the screw and the rod, not on the bearing itself.
    I suggest you print one of these in suitable size for measuring 49°±1° (and also crank/cam timing etc.):
    Attached Files Attached Files
    Sep 2009
    Sweden
    Did some googleing on the molykote and came up with
    Svenska (för glidlager), swedish (for glide style bearings)
    http://www.lundqvist.se/frameset.asp...asp?nr%3D61569
    Datasheet:
    http://www.devo-tec.de/data/pdf/techinfo_38.pdf
    can buy from here in UK it appears:
    http://www.univarsc.com/molykote-gn-...lack-1kg-GNPL1
    Ahsell (a large swedish distributer) seems to carry it too..
    http://np.netpublicator.com/netpubli...n54666425/1034
    Dec 2009
    Sweden
    Datasheet:
    Good, you did your homework better than me. Seems as if molykote on the bearing surfaces wont do any harm, a derivative from it, (Swedish molybdendisulfidfett=MoS2) is often recommended to use when assembling sliding bearings (NOT between bearing and connecting rod, only crank side of bearing). And in our engines where gearbox and engine oil is separated it wont mess up our clutch either, (given we succeed in keeping them
    separate...))
    Again, main point here is threads and contact surfaces between screw and connecting rod - we want to control screw clamping force (=screw stretch) by measuring torque applied to screw.
    Aug 2010
    Sweden
    Just did a rebuild of my rxv and used molykote (spelled molicote in manual i think) on conrodscrews bought from ashell in sweden.
    Used old conrods and screws had no problems.
