Results 1 to 5 of 5
Thread: abs wiring ????
    Aug 2010
    Greece
    abs wiring ????
    hello everybody
    this is my first time writing here
    does anybody knows where can i find abs wiring diagram for caponord 2005 ?
    apriliaforum Member breizh22's Avatar
    Breizh / France
    Quote Originally Posted by antouang View Post
    hello everybody
    This one ?
    apriliaforum Junkie McSpafter's Avatar
    Oct 2007
    Johannesburg, South Africa
    Not all 2005 models came with ABS. Although the front wheel might have an ABS pickup ring, there is no ABS module (ABS Pump & ECU) under the seat, no ABS connection wires to the front wheel or back wheel.
    Look at the hydraulic hose from the callipers; if they go straight to the brake levers, then you don't have ABS. If it goes to an ABS module, then you have ABS. The ABS Module is a black box located under the seat behind the rear shock (it mounts onto the sub-frame).
    The wiring for the ABS can be found in the workshop manual, together with the main wiring diagram (go check www.caporider.com). What seems to be the problem/ or need for wiring diagram?
    Cheers
    McS
    Aug 2010
    Greece
    i know for sure that my capo has abs but is not working anymore .... the abs light is always on
    Aug 2010
    Greece
    Quote Originally Posted by breizh22 View Post
    thanks a lot for your help !!!
