Results 1 to 15 of 16
Thread: O ring in Husky Water Trap
    Nov 2009
    Key West, FL
    Anyone know the part number or size of the O ring inside the water trap?
    Went to get some spares yesterday, but couldn't get the sucker out and when I go to look up the part number in the manual, it literally just has a square drawn for it lol.
    2009 Aprilia SR-50
    Fully Derestricted
    Cpr8e Spark Plug
    Husky Water Trap
    5.5g Roller Weights
    Bel Ray Si 7 Oil
    Sep 2008
    I reject your reality, and substitute my own. CANADA
    Quote Originally Posted by Cubanito1015 View Post
    Humm... That's a bit strange. It may not be an "O" ring, but rather a "seal". However, I'm just guessing as I've not had one of those models in my hand... But generally "O" rings should just come out. Mine has a ridge it sits in inside the Polycarbonate bowl...
    Tempus Fugit
    apriliaforum Junkie NNT's Avatar
    Nov 2009
    Vancouver, BC, Canada
    Sorry for a bit off topic, anyone know the screw size that holds the "filter/tornado" to the water trap? I lost mine when cleaning it last time. somehow the trap still work without it but I just want to install the filter back on
    09 SR 50 Factory
    ECU mapping 2.8.1
    Restrictor plate removed
    Original Reed valve with Malossi carbon fiber petal (M277054.C0)
    Porter cable water trap
    Leo Vince ZX Chrome
    Leo Vince red clutch springs
    Michelin Pilot Sport SC 140/60p13 on front and rear
    3 degree advance woodruff key
    Mutivar 2000 w 7.2g
    HGT Regulator Gen III
    Malossi Red sponge air filter
    Malossi RS24
    Also in the stable:
    2011 Moto Guzzi V7 racer
    Banned High Gain Tuning's Avatar
    Parker Colorado
    It's an o-ring and if it is stuck up there that's where I would leave it because they like to fall out otherwise. I removed my bowl dozens of times to clean and the o-ring never failed to seal.
    Nov 2009
    Key West, FL
    Yea its stuck up their for sure (which is good) so I don't want to mess with it, but should I still get some spares?
    2009 Aprilia SR-50
    Fully Derestricted
    Cpr8e Spark Plug
    Husky Water Trap
    5.5g Roller Weights
    Bel Ray Si 7 Oil
    Parker Colorado
    A leaking o-ring will keep the scoot from running but I have never had one fail.
    Totally up to you.
    Nov 2009
    Key West, FL
    Totally up to you.
    Lol alright I'll take your word for it then easier that way, thanks. You get my PM by the way? Sent one last night with the RPMs and thought you missed it again lol (I imagine how that mailbox must be), and sent another this morning.
    2009 Aprilia SR-50
    Fully Derestricted
    Cpr8e Spark Plug
    Husky Water Trap
    5.5g Roller Weights
    Bel Ray Si 7 Oil
    Parker Colorado
    Yeah... here's a current look.
    Inbox contains 444 messages.
    You have 777 messages stored, of a total 1,000 allowed.
    Nov 2009
    Key West, FL
    Holy S***! Didn't expect that much thats a LOAD!!
    2009 Aprilia SR-50
    Fully Derestricted
    Cpr8e Spark Plug
    Husky Water Trap
    5.5g Roller Weights
    Bel Ray Si 7 Oil
    Sep 2008
    So you get more as a Moderator??? NICE bonus!!
    Tempus Fugit
    Parker Colorado
    Some freaky numbers.... I am glad they were not 666
    apriliaforum expert Culverin's Avatar
    Nov 2009
    Good lord, that's ridiculous.
    What's your work email like?
    You got a secretary?
    SR50 R Factory / 2009 / Piaggio Purejet
    General
    Restrictions: Removed / Tires:
    Michelin Pilot Sport SC 130/60-13 (front and rear) w/ 2.0g dynabeads / Rider Weight: 56.7kg (125lbs)
    Performance
    ECU: unknown Version and Mapping
    Spark: NGK ZMR7AP (gapped to approx. 0.037mm)
    Exhaust: LeoVince GP, silencer removed
    Variator: Malossi Multivar 2008 w/ 6.0g DP sliders
    Contra Spring: Malossi Purple w/ Malossi Torsion Control + Stock Piaggio TC (clutch side).
    Clutch: Malossi Delta / Yellow Clutch Springs (7250 rpm engagement according to this table) / Wing Clutch Bell
    Reed Cage: Malossi VL13 (stuffer removed)
    Status
    - Clutch might still be engaging too soon? Too late? Not really sure?
    - Off-the-line lag is gone. woot.
    Parker Colorado
    Part of the reason why I am up 20 hours a day Sunday through Thursday.
    My High-Gain Antennas e-mail averages 40-60 each morning then I can usually keep them at bay and return phone calls the rest of the day. High Gain Tuning is much less thank God.
    I still find it very strange the numbers were 444 and 777 when I took a look to answer Cubanito. Maybe it is trying to tell me something.
    I personally reply to all e-mails and return all calls until I am done... no secretary for that.
    Nov 2009
    That's pretty ridiculous man.
    You could be working half of that if you had some proper help?
    Take care of yourself and don't burn out. We need you to stick around.
    General
    Performance
    Status
    apriliaforum Member InfamousJamous's Avatar
    Aug 2010
    OC, CA
    WOW that's a lot! Thanks for taking the time to reply, Rich. I try to list all the FAQs on my site and noticed a drop in redundant inquiries.
    About the O-ring, one time I forgot to reassemble it and ran without the ring. It was still air-tight and didn't stall the engine.
    06 Aprilia SR50 Morini (Spiderman Edition)
    50-53 mph LeoVince ZX Aprilia Racing Shock Buzetti Side Stand Black Tunnel Kit Kickstart Cover License Plate LED Bolts w/ Door Hinge Spider Peak Grips
    06 Aprilia SR50 Morini (Spiderman Edition) (SOLD)
    Engine: Malossi BBK, VL14 & Full-Circle Crank NGK ZMR7AP 3 Key Uni Air Filter LeoVince ZX Polished/Ported
    Transmission: Malossi Delta Clutch, Black Clutch Springs & 15/40 Gears 6.8g Rollers Uni Gearbox Breather
    Misc: Husky Water Trap HGT Gen II Regulator Buzzetti Side Stand
