Page 1 of 36 12311 ... LastLast
Results 1 to 15 of 526
Thread: Tank deforming/bulging anyone?
    apriliaforum Member Yellaghost's Avatar
    Nov 2007
    I was waxing the bike the other day and noticed this on the tank
    It wasn't there before because I wax my bike weekly and usually, the tank- both its flat and curved areas were pefectly smooth.
    I don't know what have caused it, the heat/pressure/ or whatever else because I live in Southern Louisiana and it's Dante's down here!
    I checked the black RSV4 and it too has it on one side of the tank and not both like mine, whereas the Factory is buttery smooth
    Uploaded with ImageShack.us
    apriliaforum Member RSVracer's Avatar
    Las Vegas, NV
    have you removed the EVAP canister and check valve from the vent line? The pressure is caused by those 2 pieces as they dont allow enough of the fumes to escape from the tank when the fuel gets hot and expands.
    Nov 2007
    No I haven't but I normally open the tank gas cap to let it depressurized after a long ride. I only brougth it to the dealership and seek their advice though.
    apriliaforum expert TuonoAB's Avatar
    Jan 2008
    Calgary Alberta, Canada
    The tank should not have any pressure in it ever.....Some RSVR's suffered from a similar problem, a kinked vent line usually. Removal of the EVAP canister like RSV racer said may help also.
    2008 Aprilia RSVR Bol D' Or Rep (Street)
    2010 KTM 450 EXC (Dirt)
    2007 KTM 640 Adventure (Cross Country Bomber)
    2008 Husaberg fe 450 (Project..)
    2008 Ski-Doo 800 (Rotax!) 154" (Winter)
    2007 Aprilia Tuono (Gone)
    2000 Kawasaki ZR-7 (Gone)
    apriliaforum Junkie colacin's Avatar
    Jun 2009
    Singapore
    I don't think it's a general heat issue as I've been riding one hard at the track in 90+ heat (Sepang, Malaysia) for a year. I think you have a problem the dealer should fix.
    2012 KTM 300EXC Six Days
    2011 KTM 690 Duke R
    2011 Aprilia RSV4 Factory APRC
    2008 Ducati Hypermotard 1100S
    2007 Honda CBR600RR
    Mar 2010
    San Diego
    hmm this is interesting since I've noticed the same thing as well. I will have to talk to my dealer to see what they would do since my tank had to be resprayed when I went down at the track months ago.
    apriliaforum Junkie V-4ce's Avatar
    Apr 2010
    VA
    Mine swells with pressure even with the evap can removed. But it hasn't deformed any.
    In the garage: '10 RSV4-R x2 '94&95 VFR750F '01&'09 SV650S '04 DR650 '85 VF500F '83 DT-80K '07 CBR600RR
    apriliaforum Member Hawkeye's Avatar
    Sep 2009
    A common enough problem on US Ducatis with plastic tanks. Its the ethanol in their fuel that causes this. Ducati NA warranties theirs against this sort of problem though.
    http://www.ducati-superbikes.com/for...hlight=ethanol
    http://www.ducati-superbikes.com/for...nol#post247395
    Austin, TX
    Quote Originally Posted by V-4ce View Post
    double check your vent lines.....they both should allow air to go both ways......sounds like you might still have the one-way valve on the tank vent or one line pinched behind the sprocket cover. It is not supposed to be there, and there should really be very little to no pressure in the tank with the EVAP can removed properly.
    Apr 2010
    Las Vegas
    Mine had the same problem. Take it to the dealer and they should warranty it. Still waiting on a new tank but it is getting replaced.
    Nov 2007
    Yeah, I brought mine to the dealer and had it examined. I also called Ape USA and expressed the situation to them as well. It appears then that the problem of my tank isn't unique, a sigh of relief I guess.
    apriliaforum expert Chris_Mag's Avatar
    Apr 2007
    Beaverton, Oregon
    I had a similar issue with my superduke - the tank swelled to the point that the front bolt could not be re-threaded. The bike was out of warranty, but KTM replaced the tank and I was only charged 2 hours labor (to swap the fuel pump, etc).
    Thank the US Gov for our wonderful E10 fuel.
    CURRENT BIKE
    2013 Multistrada S Touring
    2004 Tuono Factory
    Dec 2009
    SoCal, US of A
    Acerbis supplied tanks on recent bikes are doing the above.
    Also called tank spread.
    Here in The States, the EPA has mandated that smog systems must be warranted for a number of years.
    Not sure if it is 5 or more. But the tank is part of the system.
    Nov 2007
    Word is the replacement will take a while because it's in back ordered status. This sucks but it might be that my issue isn't unique, I hope a clear explanation/solution can surface??
    Nov 2009
    Quote Originally Posted by Yellaghost View Post
    This will happen again and again unless they find a way to treat the plastic inside the tank or use a different material for the tank altogether. Replacing the current production plastic tank with another one will not solve the problem, it will just happen again, just like with Ducati...
