Results 1 to 4 of 4
Thread: OHLINS question
    apriliaforum expert duc slayer's Avatar
    ny
    OHLINS question
    Do you need any special tools to re-spring and re-valve the ohlins or should the local shop be able to use the tools they already have.
    your dealer will need the ohlins fork cap tool, it is a standard tool from any ohlins forks
    KY
    Smile Yeah...you should have sent them to Clarkie
    Or you could send them to Clarkie and have him load them with the GP Suspension and use the $150 you saved on a new Evo slave cylinder!
    apriliaforum expert Chuck B's Avatar
    Phoenix, Az
    Give Dan a call (831) 394-1330 or (866) 667-4925 at www.kyleusa.com He sells the proper fork cap removal tool at half the cost from ohlins ($50). If you really want to be a redneck you can use your preload nut too but..... You'll also need a tq wrench in the 200+inlbs range.
    Chuck B
    Arizona
  1. Ohlins Upper Triple Clamp problem
    By duc900 in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 08-24-2005, 07:45 AM
  2. Question Regarding Ohlin's Steering Damper?
    By AldnEnrqz in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 08-06-2005, 05:23 PM
  3. Ohlins steering damper - adjustment range
    By millemille in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-24-2005, 02:12 PM
  4. Ohlins shock question
    By dbl_aitch in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 02-12-2004, 04:19 PM
  5. Question - Ohlins shock - differences between the 00 and the 01-03 models.
    By JohnnyG in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 01-29-2004, 07:34 AM
