Results 1 to 15 of 15
Thread: Barrymore Brake Disc
    apriliaforum Junkie Aprilliawatcher's Avatar
    Northumberland.
    Hi. During a great trip over the last few days at the Nurburgring i began to notice a slight pulsing whilst braking through the lever and forks, this got worse as the days went on and was terrible after a lap of the track. I got home and put the bike up to give it a once over and tlc after a trip. I took the brake discs off and noticed that one disc did not float at all and was seized on its buttons. The other one was fine and jangled a bit. I loosened the buttons, placed back on the bike, rode, still bad. Measured the discs with a guage as they rotated and one is as bent as barrymore. I think seized rotor buttons have caused this.
    Anyhow, i need one "used" brake disc as the other one is fine and runs true.
    If no one has a spare then im wincing at the thought of the price of a new set.
    Can anyone help in anyway, cheers peeps.
    Northumberland.
    or. Does anyone know of anywhere in the north east that can repair bendage. Ive found a couple of places on the net that can do this but they are all darn sarff fa faks sake.
    apriliaforum expert hairy's Avatar
    Nov 2004
    half sunny london
    Quote Originally Posted by Aprilliawatcher View Post
    have u tried using a big hammer,or if that dosent work,try brummy max,he might have one laying around,my bike has the exact same crap going on,but with mines its the pistons sticking a bit,going to take the calipars off today and give them a good clean,hopefully that will do the trick
    the one and only original hairy,any attempts at copying will fail ,
    cause araihead stuck his finger up a woodpeckers hole,
    and the woodpecker said god bless ur soul,
    pull it out
    pull it out
    apriliaforum expert The Dr.Jon's Avatar
    Feb 2005
    London baby!
    Barrymore discs. They awright then, you awright? Fancy a dip in the pool?
    We’re not here for a long time, we’re here for a good time
    Watch this: http://www.dailymotion.com/Omen4/vid...t-2006_extreme
    Aug 2007
    Incontinental Europe
    There is only one place for that brake disc. Chuck it in a swimming pool.
    Strange that you don't hear about Barrymore too much these days.
    HAHAHa
    Aug 2007
    I did read that Trexracing straightened one for a skint customer using an adjustable spanner or two. Gotta be worth a try, what can you lose?
    Also talk to Steve at ST motorcycles in Grantham. He is a master straightener of all things bent. Just ask AndyBev, Steve straightened him out for a few quid.
    apriliaforum expert FTM's Avatar
    Aug 2005
    Portsmouth Uk
    Sitting with the front brake on and a hot disc can cause barrymoreing. You create a hot-spot (see what I done there) and what kind of spot don't you want ... a hot spot. Different cooling rates cause warping.
    FUCK THE MAGS Nuke the whales!
    I see to recall that the ORIGINAL Tuono was around £18000 new......
    Only 200 of them made (and yours ain't one of them FTM.....) worldwide.
    The Male Whale
    Northumberland.
    Mite try the adj-spanner method tonight.
    What do company's like this do to get rid of barrymore discs.
    http://www.motoliner.com/disc_repair.htm
    Northumberland.
    Spent about an hour with markers and a gauge using two big adjustable spanners slowly trying to tweak the bender out of my disc.
    What a difference. Its less barrymore now on the eye (deffo bent) and more Kevin Spacey.
    Will road test tmrow, fingers crossed. Its great being skint.
    Northumberland.
    No luck. Its fucked. I give up. Spent 3 days on the fucker. Had the wheel off, brake disc off, cleaned hub surface, replaced disc, cleaned all caliper pistions again and again, Released all rotor button washers, tried the spanner method, and a whole host of other things, road tested and its still fucked.
    Need a new one.
    I think this has been caused by seized rotor buttons. It was like a plate from the titanic when i took it off. No give or rotation at all. The other one was fine and semi-floated no problems and is not warped.
    For fucks sake.
    apriliaforum Junkie AndyBev's Avatar
    Aug 2009
    Nottingham UK
    There is a chap in Grantham called ST Motorcycles who offers a disc straightening service if that helps...
    Tuonoless.
    Sydney, Australia
    You could always hit up ebay and buy some late 90's early 2000 Ducati supersport discs, or FZR thou yammie discs. You can check the Falco forum thread what parts are interchangeable. There is a big list of what discs will fit.
    Jun 2009
    oldham uk
    pmed you
    Northumberland.
    Sorry to drag up an old thread, but a big thanks goes out to mini_me and stev4 on this forum for helping me out with brake discs, mini_me sent a set out to the uk from the Netherlands but they were still bent 10/10 for effort to help me out, and stev4 supplied me with a set of more reliable sunstars and my brakes are fucking mint now. Thanks again lads the tuono rocks now and im so chuffed this forum has helped me out again, great people and bikers rule, stay safe, thanks to all others who got in touch with offers of help.
