Results 1 to 15 of 22
Thread: Alternative to the oem mana oil filter
    apriliaforum Junkie durdle's Avatar
    Jan 2010
    Tucson, AZ
    Anyone found a good oil filter other than the OEM filter for the Mana ?? I've searched the web and, frankly, got a little frustrated trying to find another filter. Hiflo says the HF 565 fits the Mana, Shiver and one other, but no one seems to carry it. Are there any others out there? Thanks
    Aug 2009
    Denmark
    UFI part No: 23.118.00. They also make a bigger/longer filter that fits (P/N 23.287.00) which I use myself (tip from Pete Roper). The latter is intended for some Moto Guzzis and others but works fine the Mana too and should last longer since it has more filter material than the OEM/OEM equivalent filter.
    Only downside it that UFI filters are white with blue printing which may not be optimal esthetically on all bikes but some silver spray paint took care of that on mine.
    Aug 2006
    Cleveland, Ohio, USA
    I found the HF565 at:
    http://www.mawonline.com/newsite/hif...ls___misc_.htm
    Unfortunately it's $15.95 + shipping.
    '67 BMW R69S-"Toots" in rehab
    '09 Silver SC250
    Previous rides:
    '04 Chinese 125
    '06 X9-500
    '08 MP3-400
    '06 BV500
    '09 Mana
    Aug 2006
    Also found the UFI # 23.287.00 filter at:
    http://www.mgcycle.com/index.php
    I ordered 2 filters for $17.90
    '09 Silver SC250
    Previous rides:
    '04 Chinese 125
    '06 X9-500
    '08 MP3-400
    '06 BV500
    '09 Mana
    apriliaforum Junkie SilverSurfer79's Avatar
    Nov 2009
    Plantation, FL USA
    I had a whole list of filters that I found somewhere on this site that would work. When I was about to change my oil I couldnt find any of them locally except for Purolator ML16822 (this is the longer filter) at Pep Boys and you can get it in black or upgrade to the chrome for 3X the price. Needless to say I went with the black. Hope this helps.
    2009 Aprilia Mana 850 - Removed EVAP canister, installed additional Fiaam horn, Replaced air box with cone filter/silicone tubes, Leo Vince Titanium slip on muffler, Black Jet Hot coated exhaust pipes, installed LED indicators, LED license plate light, LED compartment light and, LED ignition headlight bulb, Replaced battery with capacitor pack/LiFePO battery, Replaced front forks with RSV4R, Sachs shocks and Brembo 100mm monoblock calipers, Powdercoated wheels black. Custom paint.
    Dec 2009
    ATLANTA
    Dec 2009
    ATLANTA
    http://www.calsci.com/motorcycleinfo/FilterXRef.html
    These Oil Filters
    have 3/4" x 16tpi threads,
    8 psi by-pass valve,
    anti-drain back valve.
    and are about 3" / 3.5" long
    Recommended filters in blue. Available filters include
    Purolator PL14476 / PL14477
    Mobil1 M1-102
    Bosch 3330
    Walmart Supertech ST4967 / 4386
    AMSOil SMF 133/134/135
    Baldwin B33 / B37
    Fram PH4967
    Hastings LF410 / LF 413
    NAPA 1394
    Purolator ML16822
    WIX 51394 / 51396
    Nov 2009
    Plantation, FL USA
    Theres a nice list o filters for ya!
    Aug 2006
    But take note that some of those filters are junk. Personally I wouldn't use the Fram or Purolator. But the Mobil, Bosch and Amsoil are reasonably good. I use UFI or HiFlo and the HiFlo looks identical to the OEM filter. UFI is used in the bigger Guzzi engines.
    '09 Silver SC250
    Previous rides:
    '04 Chinese 125
    '06 X9-500
    '08 MP3-400
    '06 BV500
    '09 Mana
    apriliaforum expert JodyH's Avatar
    Jun 2007
    New Mexico, USA
    The Mobil 1 is a very good filter, the Wal-Mart SuperTech is supposed to be very good as well (according to Bobistheoilguy.com).
    The M1-102 just happens to be the same filter as my '02 Toyota PU.
    "Nihilists! Fuck me. I mean, say what you want about the tenets of National Socialism, Dude, at least it's an ethos. "
    Nov 2010
    Littleton Colorado
    Has anyone used the Wix filter ? When I had Saab and BMW cars, the independent shops all used Wix.
    Previous rides:
    2009 Mana 850, 2005 K1200S, 2004 Multistrada,
    2002 R1100S (modified), 2003 R1150RT,2005 FJR1300,
    Aug 2006
    I use Wix in some of my cars, but could not find one for the Mana.
    '09 Silver SC250
    Previous rides:
    '04 Chinese 125
    '06 X9-500
    '08 MP3-400
    '06 BV500
    '09 Mana
    Same UFI filter as is used on big block Guzzis fits and has same crack pressure for the bypass. Costs less than the 'prilla filter and is a lot better made. Lots of other x-refferences around too if you look for 'em. Or simply order in one or two of the alternatives that AF-1 recommend!
    Pete
    Professional Goat Burster.
    Aug 2006
    I use the UFI #2328700 (a Guzzi filter that Pete recommends). It's a tuff filter, when my bike fell over on my back lawn, the filter made a hole in the dirt and prevented some of the covers from getting scratched up. If I had a frame slider it would have done the same thing.
    Hi-Flo #565 is the stock size (if you can get one).
    '09 Silver SC250
    Previous rides:
    '04 Chinese 125
    '06 X9-500
    '08 MP3-400
    '06 BV500
    '09 Mana
    apriliaforum Junkie oluckymana's Avatar
    sydney australia
    hi flow is half the price of the original from my local dealer...
    ....let's have another drink....
    2011 Black Mana GT ABS
    2006 SR70
    Morini
    Polini BBK
    Chrome Leo Vince ZX pipe
    Motoforce R6 shock
    ECU in development mode
    (more when I find out what)
