Page 6 of 35 FirstFirst ... 4567816 ... LastLast
Results 76 to 90 of 517
Thread: Honda CBR600RR Mosfet Rectifier Mod
  1. #76
    apriliaforum expert bikeral64's Avatar
    Apr 2009
    Madley, Hereford, England
    Quote Originally Posted by crenninger View Post
    spaces that hold the tank on the lower corners, your side plastics bolts goes through this spacer.
    Ah, magic, thanks for that!!!
  2. #77
    Apr 2009
    Thought about all your comments, just been into the workshop again, pulled the alternator connection apart, just to check it. Found that the centre pick-up was just a few mm short of the other two. Pushed the centre wire up a bit to level them all out, reconnected the two halves of the socket. Started the motor, voltage now 14.05v on tick-over, 14.5v at 4000rpm. Does this sound more like it.
  3. #78
    May 2007
    NEWPORT SHROPSHIRE UK
    Thats spot on regards voltage, glad to hear your speedo is ok now and those spacers have a habit of dropping out of the large oval piece of rubber, i put a spot of superglue on mine to stop them falling out. Steve P.S. youve done the brown connector at the regulator end but have you done the other one to the right hand side of the cylinders ?
  4. #79
    Jun 2010
    Netherlands & Türkiye
    Now that sounds like a real FH008 voltages !
    glad you found it.
    01 Futura [infinity blue]
  5. #80
    Ireland
    You have the golden touch! Glad to hear shes coming good for you.
    A real stroke of luck with the clocks too!
    You know theres a white connector also lol and as Grumpy says theseres another brwon fecker lurking.
    Brum Brum
  6. #81
    Apr 2009
    Ah, haven't come across another brown connector, give us a clue where am I supposed to be looking now.
  7. #82
    May 2007
    Its down on the right hand side of the cylinders and is a bugger to get at, tank of job and its basicaly the other end of the yellow leads that you've just done and as TTC says make sure you do the white one at the rectifier as well cos they all go into meltdown ounce the crimped connections start corroding and go high resistance. Steve
    Have a look at the link below and post 24 will give you an idea what happens and where the connector is . Steve
    http://www.apriliaforum.com/forums/s...nectors&page=2
  8. #83
    Apr 2009
    Yes I've done the white one, replaced that with a Delphi. I'll have a look for the other one tomorrow.
  9. #84
    May 2007
    Just added a bit more and a link for you to have a look at in my post above. Steve
  10. #85
    Ireland
    I had difficulty with this connector as it was buried and couldnt for the life of me understand how folk were able to conduct finger ballet to remove the crimped spades from this brown connector, solder and reinsert.
    Luigi seems to allow more wire on some looms than other id imagine.
    I disconnted said connector and pulled it gently back out by the gene casing. I cut the connector off and soldered on some 'suitable' wire with extra length and then resoldered that. I think it was Grumpy (with his very keen electricial orientated brain) that suggested i should have gone the whole hog and ran the wires all the way to the bloody rec/reg, thats smart do it.
    This is on the list still for me.
    Either way shes working fine.
    Seeing as the tank is coming off have you stock quick release fuel couplings? If so they will need changing out as they are 50 50 likely to snap whener you disconnect em. Petrol shower time!
    Heres the thread where i 'undertook' this lol. http://www.apriliaforum.com/forums/s...d.php?t=205363
    Brum Brum
  11. #86
    Dec 2007
    Cumbria
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...n#ht_732wt_883
    Does this look like the correct reg/rectifier? Seems to be right but I dont want to commit until I'm sure its the right bit of kit.
    08 ETV 1000 Caponord
    Multistrada 1200
    Honda C90e - A real adventure bike.
  12. #87
    Jun 2010
    Quote Originally Posted by nerald View Post
    it is the correct one
  13. #88
    apriliaforum prov-nov smurf51's Avatar
    Dec 2009
    leicestershire, E-MIDS
    hi nerald,
    try and ask the seller for the part numbers on the side then cross/ref to the one's from 1st post.
    good luck, Melv
  14. #89
    Jun 2010
    Quote Originally Posted by smurf51 View Post
    hi nerald,
    good luck, Melv
    no need for that, I am 99% sure that is the correct one.
    past 2007 models has different shape . but if you wanna be sure , ask for the part number as shown on my AVATAR picture.
  15. #90
    apriliaforum prov-nov CAPOSCIMMIA's Avatar
    Aug 2009
    Milano Italy
    Hello everyone .... I have mounted this ......
    http://cgi.ebay.com/ebaymotors/FH012...Q5fAccessories
