Page 5 of 35 FirstFirst ... 3456715 ... LastLast
Results 61 to 75 of 517
Thread: Honda CBR600RR Mosfet Rectifier Mod
  1. #61
    Sweden, Linköping
    That´s why a soldered crimp does not have this problem.
    The solder will fill any space where oxidation can occur in the crimp
  2. #62
    apriliaforum expert nav18tor's Avatar
    North Essex, UK
    There is something of relevance that I have picked up from the car world, and that is the use of Dielecric grease in all connectors
    I use a Dow Corning product see
    Dielectric compound used on insulators and bushings; as a
    lubricant for high-current switches
    FEATURES
    • Nonconductive
    • Water repellent
    • Long lasting
    • Easy to apply
    • Helps prevent formation of conductive paths
    APPLICATIONS
    • Applications where improved metal-to-metal lubricity (compared to other Dow Corning® brand silicone compounds) is needed
    • To help prevent arcing and flashovers on insulators and bushings
    • As a contact lubricant on high-voltage equipment
    • To lubricate static and dynamic O-ring seals in hot-melt adhesive equipment
    • To help prevent rust and corrosion on insulator threads and bolts; also helps in removal of insulators and hardware for replacement
    • As a water-repellent filling material to help prevent moisture from travelling inside the rubber jacket of service entrance cable (can be injected using a grease gun with a needle-type nozzle)
    • To help prevent oxidation and corrosion on contacts and band-tightening
    screws of socket-type watt-hour meters
    DESCRIPTION
    Dow Corning® 5 Compound is a grease like material containing an inert amorphous silica filler in combination with
    selected dimethyl and phenylmethyl silicone fluids. This nonconductive compound is used primarily for applications requiring compatibility with rubber, metal, and plastic.
    Specific features include:
    • Easy application by hand, wiping, brushing, or automated equipment
    • Room-temperature consistency over a wide range of hot and cold temperatures
    • Serviceable temperature range of -54 to 232°C (-65 to 450°F) – a significant improvement over other
    silicone compounds
    • Resistance to oxidation, moisture, and salt spray
    • Virtually inert and non-volatile
    HOW TO USE
    Dow Corning 5 Compound can be applied by hand, brush, wipe, or specially designed automated equipment.
    However, certain dispensing equipment may seize with silicone compounds, so testing is recommended
    prior to use.
    If a thinner consistency is needed, the compound can be dispersed in Dow Corning® brand OS Fluids or
    other solvents and applied by brushing, dipping, or spraying.
    Note: When using any solvent, always provide adequate ventilation. Follow precautions on solvent container label.
    Dow Corning 5 Compound can be cleaned from a surface by wiping or washing with Dow Corning OS Fluids
    or other solvents, or by washing with detergent.
    From ebay UK http://cgi.ebay.co.uk/DOW-CORNING-5-...item3363e16687
    He who dies with the most toys wins
    Crispy X Caponord - Burned Grey - replaced with Ducati Multistrada 1000DS - Black but not crispy but now sold, Honda Transalp XL700V-8 lasted two weeks before I got bored, so got an 07 Yamaha TDM900 but then swopped it for a Yamaha FJR1300 in faster blue
    Touring Portugal? this will be a perfect base for motorcycles
    http://www.pureholidayhomes.com/coim...al-p32294.html
  3. #63
    apriliaforum expert bikeral64's Avatar
    Apr 2009
    Madley, Hereford, England
    Quote Originally Posted by Brucaliffo View Post
    Ok now I have a second hand FH008EE too, 50€ on ebay , and I received the FH008 connector kit from easternbeaver:
    My only concern now is about the original wires.... are you absolutely sure they can be blanked off?
    Friends on the italian forum suggest to use the following schema (it was designed for the FH012AA but it should be the same story), what do you think?
    I have installed the Honda 600rr reg/rec with all new connectors but still wired in to the original loom wires. I am now going to change that to a direct to battery set up, as there wasn't much difference in the voltage at battery reading. So blanking off the original wires is safe, is it not. Do I need to do anything else.
  4. #64
    Jun 2010
    Netherlands & Türkiye
    cut the wires, shrinktube it (glue ones).
    01 Futura [infinity blue]
  5. #65
    Apr 2009
    Thanks Stanleybobly, all will be done tomorrow hopefully, if I can get the small components tomorrow locally. I know a source for the Honda 600 RR reg/rec if anyone else wants one. They are £40 each, virtually brand new, off bikes that are stripped for racing.
  6. #66
    Jun 2010
    you're welcome,
    post your voltage results here ......
    (idle, 4000rpm, 4000rpm with headlights)
  7. #67
    North Essex, UK
    Quote Originally Posted by bikeral64 View Post
    That's one hell of a good price, I could not find anything in the UK and ended up spending more than double that importing one from the USA
    Mind you, it is still money well spent combined with the Eastern Beaver kit!
  8. #68
    Jun 2010
    Quote Originally Posted by nav18tor View Post
    I've got luck then , bought it from Germany € 60 + € 15 shipping to the Netherlands. Stupid bastards (breakers) here are asking around € 125, because it's from an recent modelyear bike
  9. #69
    How can you say that it is no problems for the R/R to handle 470 W instead of the 350 W?
    If nobody's answered this yet, the output rating of the alternator has nothing to do with the output rating of the rectifier/regulator.
    The 470W rating is just how much the alternator is capable of putting out.
    The actual output of an alternator is entirely dependent upon the load applied to it.
    If you short it out completely, it will theoretically put out 470 watts (until either the shorting wire, or the coils in the alternator burn out), whereas if you connect a single 40 watt lightbulb to it, it's going to put out 40 watts.
    The only possible risk to the R/R would be if you attach so many accessories to it that they exceed the rated output. And the fusebox should handle that.
  10. #70
    Jun 2010
    the FHoo8 is an 35 amp, max voltage is 14,5V
    so that's (35x14.5) 507,5 Watts of capable putting out max.
    Caponord alternator puts out max. 470 Watts
  11. #71
    Apr 2009
    O.K I have completed the mod on the reg/rec, Fitted the Honda 600RR unit, wired it direct to the battery via Delphi waterproof connectors. Result, not a lot of difference on the voltage readings, 13v on tick-over, 13.5v at 4000 rpm. The battery was fully charged, I don't know if that makes any difference. One good thing that has come from it is the speedo now works.
    Anybody regognise this spacer, found under the bike, can't recall removing it from anywhere, but it has obviously dropped down from somewhere. The battery is just to give you a scale on the size of it.
  12. #72
    Nov 2009
    Redwood City, CA - USA
    spaces that hold the tank on the lower corners, your side plastics bolts goes through this spacer.
  13. #73
    Jun 2010
    Result, not a lot of difference on the voltage readings, 13v on tick-over, 13.5v at 4000 rpm. The battery was fully charged, I don't know if that makes any difference. One good thing that has come from it is the speedo now works..
    that voltage will kill your battery,, hmmmmm I suppose your alternator isn't good at all. There is a test, to see if your alternator is in a good shape or not.
    I don't know how it was..
  14. #74
    Ireland
    You my friend have most likely a brown connector issue.
    Brum Brum
  15. #75
    Apr 2009
    Quote Originally Posted by the_toe_cutter View Post
    I've done away with the brown connector, all connected with Delphi connectors.
