Page 35 of 35 FirstFirst ... 25333435
Results 511 to 517 of 517
Thread: Honda CBR600RR Mosfet Rectifier Mod
  1. #511
    May 2016
    Done with the road test. And here are the results from a multimeter attached directly to a brand new Yuasa YTX14 battery:
    - idle with no load: 14.05-14.1V
    - idle with all lights on - 13.6-13.7V
    - over 4krpm with all lights on - 13.85-13.99V
    Couldn't reach 14V under full load at any revs.
    The rectifier was stone cold on the move, getting slightly warm after few minutes of idle, but there's below 20 Celsius here today.
    Voltage drop I was worried about(braking light, turn indicators)?
    - above 2krpm there is none at the battery, but accessory voltmeter shows immediately 0.5-1V drop
    - 0.2-0.4V drop at the battery when idle
    Gonna do that negative wire bypass for the pace of mind and forget about the whole thing while it's working
  2. #512
    Jun 2018
    teesdale
    Hi, Are the Honda reg recs still available...if so how can I get my hands on one?
  3. #513
    May 2012
    Norton In Hales Shropshire
    If you're looking brand new then a honda dealer - Think they are from a CBR 600. Starts with FH008 on the part
  4. #514
    Jun 2018
    teesdale
    Will a FH008EH from a CBR1000RR fireblade 08-16 work ok?
    What size of wiring should be used to join the 3 x YELLOW wires from the alternator to the regulator and then the regulator to the battery 1 x RED and 1 x GREEN ?
  5. #515
    May 2018
    Massachusetts (USA)
    https://www.ebay.com/itm/NEW-VOLTAGE...72.m2749.l2649
    Here is link to one on ebay i recently purchased and installed. Working well and only $28!!!
  6. #516
    Sweden, Linköping
    Quote Originally Posted by TarMack View Post
    I hope you can monitor the voltage with that cheap thing installed.
  7. #517
    May 2018
    Massachusetts (USA)
    14.2v at idle. Will keep an eye on it.
