Page 6 of 8 FirstFirst ... 45678 LastLast
Results 76 to 90 of 119
Thread: New LeoVince ZX-R
  1. #76
    Parker Colorado
    The exit pipe is the same, 20mm OD but might have a larger radius to it to accommodate the silencer.
    The good news is the 3 bolt pattern is the same, 40mm across so the new silencer can be bolted to an older ZX pipe if you also order the hardware kit.
  2. #77
    apriliaforum expert Lorenzo's Avatar
    Jan 2008
    Golden Triangle, Texas
    So, will the new and larger ZX-R silencer, in theory, make the older ZX pipe quieter?
  3. #78
    Parker Colorado
    I would sure think so....
  4. #79
    May 2010
    Norway
    Are you able to try that out, HG? An easy bolt-on mod like that would sure be very attractive to all ZX users in here.
    What do you suggest the pricing of the silencer would be?
    And, could you please verify if the roller/springs thats shipped with the euro Piaggio ZX-R is the same 5.1g/red clutch as the ZX did.
    I remember you said stock derestricted Piaggio had 5.3, ZX shipped 5.1/red clutch and if you were at high altitude 5.0/red clutch would be a good starting poin when experimenting with rollers, right?
    Aprilia SR50 Factory 2006 Piaggio "Purejet" (Norway)
    Exhaust: Stock ATM, LeoVince ZX lying around (acc. improved, but top speed dropped more rapidly in wind&uphill)
    Derestrictions: ECU (2.8.0) & Variator & air intake plate derestricted
    Speed/RPM: 80kmph@9000, 85kmph@9500, top 87kmph@9700. 78-85 on flat depending on RPM-momentum, wind etc.
    Spark-plug:
    - NEW! NGK ZMR7AP fixed the sputter, runs clean the whole rpm range! BUT slightly less "punch @WOT compared to the champion plug "
    - Original spark-plug (Champion), sputters when gliding at about 7000rpm. Runs beautifully @ WOT.
  5. #80
    apriliaforum expert Culverin's Avatar
    Nov 2009
    Vancouver, BC, Canada
    My LV ZX Piaggio came with 4.5s and red clutch.
    I thought that was the norm.
    SR50 R Factory / 2009 / Piaggio Purejet
    General
    Restrictions: Removed / Tires:
    Michelin Pilot Sport SC 130/60-13 (front and rear) w/ 2.0g dynabeads / Rider Weight: 56.7kg (125lbs)
    Performance
    ECU: unknown Version and Mapping
    Spark: NGK ZMR7AP (gapped to approx. 0.037mm)
    Exhaust: LeoVince GP, silencer removed
    Variator: Malossi Multivar 2008 w/ 6.0g DP sliders
    Contra Spring: Malossi Purple w/ Malossi Torsion Control + Stock Piaggio TC (clutch side).
    Clutch: Malossi Delta / Yellow Clutch Springs (7250 rpm engagement according to this table) / Wing Clutch Bell
    Reed Cage: Malossi VL13 (stuffer removed)
    Status
    - Clutch might still be engaging too soon? Too late? Not really sure?
    - Off-the-line lag is gone. woot.
  6. #81
    May 2010
    Norway
    I used to think 4.8 and red clutch spring was recommended, before HG posted THIS
    What to order? 5.1g, 4.8, 4,5? Red clutch spring seems to be a common denominator, tho
    Spark-plug:
  7. #82
    Parker Colorado
    Well.....
    Let me clear up some confusion that I just found out myself.
    I remember posting the 4.8gr. post and even posted a pic of the package of rollers.
    Even more recent I remember posting the 5.1gr post as I weighed the rollers myself since I did the work.
    Well, here's the problem and no, my scale is not off.
  8. #83
    Sep 2008
    Nice weather AT LAST! Winnipeg, MB
    Well.....
    That's just a wee bit of a difference... I can't believe that they are off by THAT much!! I mean .1 maybe... but .3?
    I assume that they get the weights from another supplier and don't do much (if anything) for Quality Control...
    Anger is an ugly Mistress…
  9. #84
    Parker Colorado
    Just another thing to bring to a manufacturers attention..... They are really getting tired of me.
  10. #85
    apriliaforum expert Haribolman's Avatar
    Gold Coast
    Talking about Leo Vinci pipes, the thing I don't understand is how the pipe forms an effective seal against the engine exhaust outlet. When I removed the Leo Vinci S pipe that came with my '07, there was no gasket, simply some unusual "spring type material" wrapped around the outer edge of the pipe's inlet hole. How exactly does this stuff form a seal? It just doesn't look possible! And yet, I tried the pipe on my '02 and it worked fine, no leaks. So obviously , this spring-type material works, but I don't know how!
    Go Vegan!
    ASM - CBT - EFT - NVC
    M - P - SIP
    BOM - IMDB - NEWS - UFO
    I & L
    Silver 2007 SR50 R Factory
    Haribolman has promoted SAFE RIDING for over 30 years.
    Life is precious. Be proactive and responsible.
    Always wear a helmet, gloves, jacket and safe footwear.
    (This signature was approved by my legal representative)
  11. #86
    apriliaforum Junkie thamil's Avatar
    May 2008
    Vegas
    dont know why they would be... companies pay $millions for product testing like that. they get it from you for free
    HELLO 2009 White SR50
    Leo GP Pipe . BGM 6.0 g rollers . 3° Woodruff key . Marchald Intake . Malossi VL13 Reed Block . NGK ZMR7AP . BGM LED Tail . HGT Brake Levers . Buzzetti Side Stand . SirDyza White Foot Pegs . Covered In Rhodesian Ridgeback Hair
    BYE BYE 2006 Red SR50
    LED Tail . Smoked Lenses . Dealer De-restricted . shoelace-less K-swiss shoes . Fully De-restricted left hand
  12. #87
    apriliaforum newb KlanenForce's Avatar
    Jul 2009
    N/A
    Bump?
    Any news HG?
  13. #88
    Parker Colorado
    I received in Piaggio ZX-R's and already sold out
    Morini ZX-R's arrive next week
    More Piaggio ZX-R's arrive in 1 1/2 weeks
  14. #89
    Jun 2010
    yardley pa
    Do we have any results on this new pipe, like quiter or more top end anything you may have found?
  15. #90
    Parker Colorado
    As far as I know, all that were shipped were first time performance pipe owners so I don't believe we will have any comparison data this round.
    I received this in an e-mail today..... very interesting. This is a 2009 Piaggio
    I really like it, it is not any louder than the original exhaust. I installed the exhaust and rollers and it improved the performance. Now I am getting 8.5 rpm on take off.
    No louder than the original.....
