Results 1 to 13 of 13
Thread: Anyone able to look up a eibach shock rate?
    Jun 2009
    The eibach spring has 16730 on it. I googled it any was not able to get a good hit. Need to know what weight of rider it is rated for.
    Mar 2007
    Palos Verdes Est. SoCal
    boingers
    what rate spring are you looking for?
    whats the rider weight?
    Noel-theknurl
    Noel-theknurl
    The Forum Curmudgeon
    I'm not PC either
    ph. 310-540-4823 PST, GMT -8
    New Braunfels, TX
    if you just pay for shipping, I'll measure it on our digital spring rate tester for free.
    I love that instrument....looking for any excuse to use it.
    Ed Cook AF1 ed@af1racing.com
    AF1 Racing Online Store
    Mar 2007
    Hi Ed;
    hey do you have an early '04 Sachs spring you can test and post up the results? which spring tester do you have?
    PM me if you don't have an early one
    thanks
    Noel-theknurl
    Noel-theknurl
    I'm not PC either
    Jun 2009
    Quote Originally Posted by theknurl View Post
    Noel-theknurl
    Need a spring rated for a 220 lb rider. The one I have on my new to me Penske shock now is WAY to stiff. I went for a ride the other day and thought I was going to need a chiropractor when all was said and done...
    Scuba
    Jun 2009
    Ed, if no one has/is able to provide the info I will take you up on it. Thanks, appreciate it.
    ETA.
    There is also the #s 00600.225.0600 on it....
    Scuba
    Mar 2007
    Scuba;
    what rate spring do you want.....what is the free length of the Eibach on your Penske?
    Noel-theknurl
    Noel-theknurl
    I'm not PC either
    Jun 2009
    Scuba;
    Noel-theknurl
    The Eiback is on the Sachs I had taken off. The Penske shock has a penske spring on it.
    New Braunfels, TX
    we got the Intercomp setup with fork spring adaptors too
    I'll look to see if we have a known 04+ Sach shock spring to test.
    Mar 2007
    Talking
    Ed;
    let me know, i have mine off #111....
    the Intercomp setup looks great.....toy bank account is flat.....other toys got there first LOL
    Noel-theknurl
    Noel-theknurl
    I'm not PC either
    Jun 2009
    Ok...found out that it is rated for 600lbs. Now...how do I tell if that is an appropriate for me?
    apriliaforum prov-nov CP598's Avatar
    Apr 2008
    Moses Lake Washington
    600 should be just about right for your weight, maybe just a bit stiff but still acceptable.
    07.5 Tuono
    06 Husqvarna TE510
    Mar 2007
    Talking
    600 in/lb beat me to death @175lbs....PM Scott2ride, i think he is the same weight
    my current rear spring is an Ohlins 1091-24/80
    its 457 in/lb
    i have a 1091-21/75 which is 428 in/lb that i want to try, when i have the time
    DO NOT TAKE THIS AS A RECOMMENDATION!!!!!
    i was a frame designer/fabricator and test rider for F.W. Egli, its what i like....you might not
    another thing, my rear damping on the resprung stock Sachs is WAY less than stock, comp 1.5, me 2.5, rebound stock 20 clicks, me 35 clicks
    my sag is like everyone's, but the light spring needs more preload to get there
    it works for me, i've been doing this for a long time.....
    i will never sell my RSV unless i wad it, and then i'll just get another one.....and set it up the same....or maybe make a tube frame instead of the beer can one.....lol
    Noel-theknurl
    Noel-theknurl
    I'm not PC either
