Page 1 of 6 123 ... LastLast
Results 1 to 15 of 80
Thread: How to convert a 98-03 Mille to a Tuono
    Aug 2007
    Incontinental Europe
    You need these parts:
    Relay and fusebox plastic shrouds
    Part numbers 1 & 6
    AP8168058
    AP8168059
    Front indicator mounts and countersunk bolts
    Part numbers 9, 10 & 2 x 11
    AP8134897
    AP8134896
    2 x AP8152566
    Front brake master cylinder U-bolt
    Part number 6
    AP8168501
    Clutch master cylinder U-bolt
    Part number 8
    AP8168217
    Bellypan brackets
    Part numbers 7 & 8
    AP8134894
    AP8134895
    Coil cover bolts
    4 x part number 12
    4 x AP8134923
    Radiator end spacers
    4 x part number 16
    4 x AP8152436
    You will also need to get longer brake lines. Make sure you get the correct angle banjo fittings for your calipers. If you have the 4 pad Mille R calipers then standard Tuono lines will have the wrong banjo. The original 2002 Tuono limited had the four pad calipers. All other Tuonos have either 4 pad radial calipers or 2 pad standard calipers.
    You also need a longer clutch line.
    There are various options for top yoke, bar and risers. If you get standard ones, be sure to get the correct top yoke for your forks. Ohlins forks have 51mm fork clamps and Showa forks have 53mm fork clamps. Some people have used 1mm aluminium sheet bent as a spacer for the Ohlins forks with the Showa top yoke. LSL and ABM also do top yoke kits with risers. The streetfighter store sells kits that include top yoke, risers, bars and longer brake+clutch lines. See here: Aprilia yoke kits. Be aware that their brake and clutch lines are not long enough for standard Tuono risers. On their kits, the risers are lower. When swapping top yokes, move the Mille wiring loom from the outside of the forks to the inside. You also need to move the air temp sensor from the left hand Mille air tube to the left hand front relay shroud. There is a threaded hole that it screws into.
    The brackets that hold the clutch fluid reservoir and front brake reservoir are slightly different on the Tuono. You can buy the genuine Tuono ones or slightly bend the existing Mille ones.
    You will need a pair of mirrors. 2006+ Tuono mirrors also work well.
    You can buy standard Tuono crash bungs or the R&G offering parts. The R&G ones hold up better in a crash.
    You also need front fairing, screen, bellypan, coil covers, coolant bottle cover, radiator ends and air scoops/intakes. It is possible to cut down the Mille bellypan and front fairing. If you want a genuine tail end on your Tuono you need an 03 Mille or 02-05 Tuono rear plastic. If you are converting a 98-00 Mille and are changing to a genuine Tuono rear plastic, then you also need the 01-03 Mille taillight without the plastic shroud or an 02-05 Tuono tailight. They are the same. If you are changing to a genuine Tuono front fairing, then you will also need a Tuono screen. It is shorter than the Mille screen and only has 6 bolts, not 8. The radiator ends bolt on through 4 plastic spacers. You can either buy the genuine spacers or find an alternative locally.
    The standard Tuono front subframe has a C shaped bracket welded to it. This reinforces the tube that comes from the headstock. The Mille does not need this because the air tubes and fairing partly support the front fairing, subframe, clocks and headlight. Here is a Mille subframe that I had modified:
    Aug 2007
    This is my conversion from what I started with to what the bike became.
    apriliaforum Member MD RSV's Avatar
    Apr 2007
    Nice writeup Max. Need to touch on the fairing bracket mod.
    Aug 2007
    Quote Originally Posted by MD RSV View Post
    Yep. I also forgot radiator ends with the little plastic spacers and Tuono screens
    I will edit it.
    Hank, make this a sticky because I get many PM's asking about this so am forever repeating myself!
    apriliaforum expert AliPisha's Avatar
    Jan 2007
    Brilliant write up Max
    apriliaforum prov-nov yogurt's Avatar
    Jan 2009
    lincolnshire,england
    Dont forget this one stated life as a mille!
    me holding my exhausts!!!!
    Jan 2007
    Feckin hell do you ever ride that?? it looks immaculate!!! Feckin orrible but immaculate
    apriliaforum expert hairy's Avatar
    Nov 2004
    half sunny london
    and heres me thinking u just stick an pair of tuono bars onto it,good write up dude,but i would have kept the yellow paint sceme
    the one and only original hairy,any attempts at copying will fail ,
    cause araihead stuck his finger up a woodpeckers hole,
    and the woodpecker said god bless ur soul,
    pull it out
    pull it out
    apriliaforum expert Batfastard's Avatar
    Aug 2005
    North Lincolnshire, UK
    Wink
    Quote Originally Posted by yogurt View Post
    Are you the Yog from Goxhill?
    apriliaforum expert FTM's Avatar
    Aug 2005
    Portsmouth Uk
    Quote Originally Posted by Batfastard View Post
    With the Gixxer streetfighter?
    FUCK THE MAGS
    Never live the same day twice. (My wife nearly pissed her self laughing when she read my signature line, because she reckons she has never met anyone in the whole of her life who hates change more than me) She does have a point .
    Jan 2009
    yes mate
    Jul 2009
    Greece
    tell us and what items we need to convert it from tuono to mille
    Jun 2010
    AZ
    I want to do the same to mine, change from Tuono to Mille.
    I am done with the streets and keeping it on the track. Any advice?
    apriliaforum Junkie AndyBev's Avatar
    Aug 2009
    Nottingham UK
    I have a mille top yoke which i will swap for a tuono one if you like?
    Tuonoless.
    Aug 2007
    Quote Originally Posted by tattsailor View Post
    Well I can supply you with most of what you need. I will swap for some of your parts if you want. The only things you will need to find elsewhere are airscoops (left + right, inner + outer), screen, top yoke and clip ons.
