Results 1 to 11 of 11
Thread: Some closure for you
    apriliaforum expert ThEGr33k's Avatar
    Jan 2008
    England - Yorkshire - Barnsley
    Well I thought since (im quite sure) I've been annoying people with many many questions over the past few months asking about possible causes of that damn 3K rpm stumble...
    Well I seem to have remedied it finally *all cheer!* so thanks for putting up with me all this time and giving me idea's, its been testing for me but I finally saw it through and it seems to be 99% sorted. The rest a Power Commander tune for 100% good fuelling will sort I think.
    What I did;
    Replaced the Throttle bodies with some newer and much cleaner ones off of Ebay. Balanced them and its running much better. Guess I cant say for certain what was wrong with the original set as im using new fuel pressure reg and injectors but if I was to guess; id guess slightly slow/clogged injector...
    Glad that seems to be over!!!!!!!!!!
    Dyno Run
    Blue line = standard eprom and baffles in
    Red line = Gabro eprom and baffles in
    Green line = Gabro eprom and baffles out
    HUNGRY for knowledge!
    Sunstar Disc's|EBC HH Pads|4pad brembo callipers|Radial master cylinders|Evoluzione clutch slave|Hel Braided hoses|K-Tech 9NM fork springs|Penske racing shocker|RSV 01-03 Suspension linkage|RSV Swing arm|Lowered front & Raised rear|Carbon bits|Bef exhaust system|Large intake system|PC3 + Advanced custom map|Gabro Eprom
    apriliaforum expert paddyz1's Avatar
    Jul 2005
    Cheshire
    So what will be the next problem
    apriliaforum expert D-Rider's Avatar
    Jul 2005
    Coventry, England
    Quote Originally Posted by paddyz1 View Post
    ROFLMAO
    Paddy - you've just made a grown man cry !
    Jan 2008
    Shhh, none touch wood! I honestly dont like having issues.
    Not problems but I have some 4 pad calipers to fit (waiting for one of the springs that hold the pads in to come as one is missing), might also have to chase some Oz wheels... Wish me luck!
    Quote Originally Posted by D-Rider View Post
    ROFLMAO
    I knew I was well regarded, didnt realise how well...
    Dyno Run
    Jul 2005
    Coventry, England
    Now, those 4-pad callipers ..... don't get any ideas about stripping them down and servicing them before you fit them .... (though, obviously do make sure they are in good order before you come to use them)
    I've also got a set waiting to go on but I thought I'd strip them down first ....
    ..........body count so far .... 1 torx bit twisted, 1 brand new chrome-vanadium torx bit snapped .... callipers still together (2 torx bolts loosened, 1 won't shift) ..... 1 impact torx bit now being procured ....
    .... and I only wanted to get the seals out so I could find out what they are and find a good source for spares ......
    Sep 2008
    Sheffield UK
    (Sigh) - you could always have asked, Andy. I stripped mine down over the winter and gave them a quick going over. Once again, KTM came to the rescue...
    And the Torx bolts were a tad tight, I must admit...
    Jan 2008
    They do look good to be honest so I wasnt planning on any strip tease with them.
    Dyno Run
    Jul 2005
    Coventry, England
    LOL ... never mind, Graham - I'd sooner service them before putting them on TBH.
    I was fairly sure that KTM would be a good backup but I'm hoping that Chabi on Ridersite can use his contacts to find a good match like he did with the OEM clutch slave seal.
    .... and once I've got these 4-pad beauties on there, I'll strip the standard callipers to try to source seals for them too (in addition to the KTM source) ...
    Sep 2008
    Sheffield UK
    Yes, I agree that finding some alternatives is definitely the way forward. It's good to know that KTM can be used as a back-stop, but they're pricey for what they are and you are forced to buy an overhaul kit that includes pistons and seals. Being an honorary Yorkshireman I object to paying through the nose for a few rubber seals...
    Jan 2008
    I didnt actually realise they did the 4 pad ones, knew about them supporting 2 pad ones. Good to know.
    Dyno Run
    Jul 2007
    Netherlands
    Glad you sorted it out nick! Now what to do wil ALL THAT SPARE TIME?!
