Results 1 to 11 of 11
Thread: front brake rotors of a Shiver...
    apriliaforum prov-nov Tikitulamutu's Avatar
    May 2007
    Spain
    hi mates!
    I bought an RSV from 00' last week and realized that the front rotors need to be changed.
    Aaand I would like to fit the front rotors of an Aprilia Shiver.
    Do they use the same rotors linkage ¿?¿?
    Feb 2006
    Houston, TX
    No. The shiver has radial front brakes. The offset is completely different.
    Jul 2007
    Middletown, CT
    Why do you want to use shiver rotors? It does appears that they are interchangeable with the later models but as stated, not with the earlier non radial versions
    Quote Originally Posted by Kane View Post
    the aprilia kicked the 919s ass while you werent looking and the 919 pissed its battery fluid all over itself and.then died.
    Current Stable:
    2001 RSV Millountura (Gia)
    2000 RS250 (Erin)
    2001 RS50 (Kitt)
    2007 919 (Jen)
    2000 CBR929RR (Jonni)
    1984 XR500R (Lucy)
    1960 BMW R60/2 w/sidecar (TBD)
    1972 CB450 K5 (TBD)
    200? RSV Mille (TBD)
    Gone but never forgotten:
    2001 SV650S (Linda)
    1982 CB550 Nighthawk
    1972 CB450 K5
    May 2007
    Spain
    Quote Originally Posted by soofle616 View Post
    Thanks a lot dudes!
    It is because mine are not in good conditions, and I've been looking for used pieces of crashed bikes and the only thing I've found (in very good conditions) was a broken Shiver with less than 7000 km's.
    My brake lever vibrates (like moving up and down) while braking so I think it must be one of the rotors...
    I'm spanish so my engurish is quite bad >,< Sorry!
    Quote Originally Posted by kick6 View Post
    The offsets are controlled by the hub and the caliper mounting. Discs are interchangeable between radial mount and standard mount brakes.
    The Shiver disc will fit the 2000 mille but it has a narrower swept area so the standard 2000 pad will overhang the disc slightly at the inner diameter of the swept area.
    http://www.af1racing.com/store/Scrip...idproduct=5809
    Feb 2006
    Houston, TX
    Oh wow. Thanks for that.
    May 2007
    Spain
    Here I am again!
    As I've seen, is known that the front discs of a 916, 996 and 748 are direct swap in our RSV's, but:
    Are all kind of front discs from Ducatis direct swap on the RSV's ¿?
    For example, this ones:
    Uploaded with ImageShack.us
    are the same as the ones on RsV 99-2000.5 (not sure but, mine are the same in black)
    And this ones :
    are not the same looking. Will they fit anyway ¿?¿?
    They are much much better looking than our stock front discs...
    byee!
    Aug 2007
    Incontinental Europe
    May 2007
    Spain
    Quote Originally Posted by BrummyMax View Post
    wuuoo
    that's my problem! When push the brake lever it vibrates and theres a lot of pulsating movment...
    Damn.. I can't see those pics >,<
    I'll check tomorrow n.n
    thanx!
    Aug 2007
    The pics are there, check the next pages.
    Quote Originally Posted by Tikitulamutu View Post
    Here I am again!
    For example, this ones:...
    ...are not the same looking. Will they fit anyway...
    Both of those discs will work. I have a set like your second picture.
