can someone post an rs 125 engine pic with mounting points shown and roughly measured ??? width of mounting points and distance from other mounting points??? cant find anything on google
RS125 engine wont fit (Rotax) you need a Cagiva Mito 125 Engine, but its not a question of just fitting an Engine in the RS50
But if you really want to go ahaed and stick a RS125 engine in your RS50 frame look for help in the 125 section.
Already told you its much better to just tune your AM6 engine up, if you do it right you make those guys on there 15HP RS125's cry wen you leave them in your dust with your tuned AM6.
i get what your saying but i need reliability so 125 engine would be best ..... and rs 125s have 33hp unrestricted ..... what 125 engines would you recommend ?? and you think would be the easiest to fit ?? im open to hearing what 125 engines ..... not sure what one myself ...
Already mentioned wich one up there, and with a 125 engine in a RS50 its not gonna be more reliable at all, you get all sorts of frame and suspension isues.
I dont know what your trying to achieve but my RS50 AM6 with 75cc did 3000 miles problem free and i only removed the tunning parts because my bike would have been impounded and schredded if i didnt bring it back to 30mph max (it actualy was impounded but they screwed up the papers on the impound so they had to give it back, but i had to show it "restricted" with in a week)
Sold the Cilinder together with some other tuning parts to someone in the USA after that.
whats the mods that you done to your bike and what difference did you see i.e speed and acceleration ??
im guessing the standard parts for beefing up the rs50 are:
70-80cc BBK
reed valves to go with it (0.5?)
21mm Dellorto Carb
new exhaust
new Sprockets (don't ask me what ones!)
optional:
Maybe a new Crank (not sure of the difference though)
New Clutch discs (the barnett kit is supposedly the best)
new cdi? (really not sure on this though :P)
anything im missing? :P
the majority of those thing have been done on my bike, and must say its awesome. i can do about 50+ in 5th with out being in stupid rpms
if you swap the engine for a 125 will you register it as a 125?
omg i am right for once!
but i think a totally kitted up rs50 would beat a stock 125 Japanese import? due to build quality and weight. As most of them are only 11bhp or something silly
+-140kmh/90mph and acceleration faster than most cars.
Race Crank (Dopler ER1)
Big Bore Kit (Top Performances "Pink" 75cc and porting done)
Exhaust (Giannelli race with Kevlar silencer)
Clutch Kit (Top Performances with Spring mod)
Reedcage (Top Performance Reedcage with 0.50mm reeds)
CDI (Top Performances yellow)
Sparkplug (NGK B11EGV)
Carb Kit (24mm Mikuni with 26mm Intake and Custom Throttle Cable and Custom adapter for Airbox, and Moded Oilinjection system)
Stock Airbox (Moded Intake and Extra Intake tube)
Sprocket and Chain (15T Front, Stock size rear)
High Quality Fluids
High Quality Brakepads
High Quality Tires (Pireli MT75 S Rated)
And some other small and cosmetic mods.
(Posible new setup together with the above)
Top Performances 86cc kit
Top Performances Clutch Unit
Close Ratio Gearbox
Exhaust that can handle 86cc or a Custom made pipe
Chain and Sprockets
Any pictures of the port work Patrick?
RIP Spike
Dont have any pictures of the Open engine and only some low quality ones (old cameraphone) of stuff installed and some pics of the Airbox mods.
Next time i take it apart i (or the other engine) i make a project gallery out of it as i got a good camera now for that.
Other than that you wouldnt be able to tell anything from the pictures as the changes where just minimal and mostly amaimed at getting a better flow trough the cilinder.
Onlything on there now is the 24mm Carb (my 12mm broke), a old 50cc Stock Cilinder, with the wrong head, raised the exhaust port to still get a bit of power, The Ehaust and the Ignition unit, and it runs like crap, but i only had to get it running because i needed it to get to work for a week or 2 so didnt need the speed and power but was suprised i got it to run with the 24mm carb as an emergency replacment lol
Its dead at the momend though so i need to look at what im gonna do with it first, make it stock or tune it again (and risk it being impounded together with my drivers licence)
So making it "stock" probably is the better choice here.
