Page 5 of 7 FirstFirst ... 34567 LastLast
Results 61 to 75 of 94
Thread: Tech Tips thread
  1. #61
    Dec 2010
    Greece
    Replaced the main wiring harness on my 2002 Capo. Over the years, I've wired in harness bypasses when I lost a harness connections, but there were getting to be many. Aprilia dropped the price to less than $200 (from $650!), so it followed me home;
    Attachment 261399
    Rumors claim Chinese wiring harnesses, but can you tell us what this language is?
    Attachment 261400
    Attachment 261401
    That's definitely Greek.
  2. #62
    Morgan Territory, CA
    Quote Originally Posted by Precis View Post
    I believe it's Greek.
    And those BC spades STILL aren't soldered? Unbelievable!
    Quote Originally Posted by Bloodyheaven View Post
    Thanks for the language info gentlemen. The Greek math symbols were obviously NOT Chinese.
    The automated wire-crimping machines don't know how to solder!
    Catfish ...
  3. #63
    May 2008
    GREECE
    Catfish, that sticker shows that the harness went to a trip to a greek dealership. Seems never installed and somehow went back to aprilia central (in Greece or Italy) and then shipped over to US.
  4. #64
    Jul 2012
    Chorley, Lancashire
    The looms are made by the french and use citreon connectors look at the ecu plugs and you will find the << of the manufacturer
    aprilia used french electrics all over the bike including french sagem coils(later jci ) & injectors. Even the AICV motor is french.
    This I feel is the greatest weakness of the caponord/futura. Not that the mille etc italian looms were much better.
    Me n' Mine:-
    2006 Caponord ETV 1000 "Twiki"
    2004 Tuono Racing Rep, Full Carbon with SBK 2-2 Akro's
    2002 ZX636 A1P Ninja list of mods is endless
    "Made in Italy....Perfected in my Garage"
    I've never questioned why I ride, it's as basic as breathing.
  5. #65
    May 2014
    United Kingdom
    Heated Grips not working and Hazards intermittent?
    If you can solder and are not colour blind try this.
    Remove the switch box from the r/h grip mount and unplug the two waterproof connectors behind the screen (4 way and a 3 way). remove the whole assembly from the bike and take to a bench.
    remove the adhesive gunk from the back cover (looks like some kind of varnish sealant) and GENTLY prise open the box. inside you'll find lots of rust and cr@p and a few bits of switch if it's anything like mine.
ID:	264933Click image for larger version.
ID:	264934Click image for larger version.
    Gently remove the rest of the gunk
    Unsolder all the wires and try to guess where they go when you put it back together
    OR use this diagram as a starter:
    I bought two replacement switches and waterproof cover from MAPLIN (other electric stores are available) for less than £12
    When resoldered and all put back together Test it on the bike BEFORE you feed cables through, I found out that I'd put the heated grip switch in the wrong way round so LOWis high and High is Low - but I know so........
    Final job is to reseal the back cover on to the box, I used some of this stuff:
    and, with a bit of wet finger it ends up looking like this
    or better
    £12, half a day and hopefully it will last another 7 years +
  6. #66
    Dec 2007
    Cumbria
    Fuel connectors - Viton seals (sizes)
    08 ETV 1000 Caponord
    Multistrada 1200
    Honda C90e - A real adventure bike.
  7. #67
    Jun 2010
    Netherlands & Türkiye
    fitting Chainslider
    silly "noisy" chainroller replacing it with the slider (oem on 2003 and on Caponord)
    removing it:
    exploded view:
    now we need the galvanized spacer
    mine case it didn't came out easily, so grabbed the torch and melted the surrounding plastic
    after a few second it started stripping for me , Now your are my baby
    fitting the slider with these components
    assembled
    01 Futura [infinity blue]
  8. #68
    Oct 2014
    Belgium-Antwerp
    Hello to all, allow me to introduce us both being CapoLudo the driver and the beast as being the Caponord ETV 2003 with 78000km and in almost perfect shape.
    But, can anybody direct me into the right direction for finding one of those full bearings repalcement kit for a rear swingarm of a ETV 2003?
    Greetings,
    CapoLudo.
  9. #69
    apriliaforum Member breizh22's Avatar
    Breizh / France
    Sump guard RallyRaid look =>
    http://www.wilkuj.cba.pl/en/sump-guard.html
  10. #70
    Oct 2014
    Belgium-Antwerp
    bearing kit capo
    Hello Brucaliffo,
    I'm a new member on this forum and I wanted to ask you if it's till possible to order one full bearing kit for the connection rod of the swing arm for my Caponord 2003?
    yesterday I discovered while working on my Caponord that they are all completly worn out and rod pins+ seals also.
    I was in contact with Karl Bianchini from abruzzo.com and he directed my to you. And I noticed in the threads that you are the wright person.
    Is it still possible?
    kind regards
    CapoLudo
    Belgium
    ETV 2003 - XRV 750 - KTM Adv R
  11. #71
    Cooma N.S.W.
    Just realised my valve shim kit is actually a KTM one http://www.ebay.com.au/itm/Moose-Rac...item35dc0b9a35
    JohnG.
    '02 Capo.
  12. #72
    apriliaforum prov-nov sanausbe's Avatar
    Sep 2012
    Istanbul
    Be carefull with the chassis. I have seen two of them broken from different points.
  13. #73
    Jun 2010
    Just don't crash them at the front
  14. #74
    Jul 2012
    Chorley, Lancashire
    That was my first thought stanley lol Capo frames break at the side stand fixing point more often than a head stock imo obviously without a head on whoopsy.
    Me n' Mine:-
  15. #75
    Melbourne, Australia
    For those that haven't changed the Clutch Slave Cylinder yet, Factory Racing in the UK are selling some cheap (GBP60), to create some cash-flow.
    http://www.motopike.com/index.php?ro...th=247_249_293
    If you're outside UK, it'll be less their 20% tax, but plus some for freight.
    Note that I had one fitted to my wife's Capo and after a long time of sitting still, it failed. I enquired after a seal kit and Adam replied very quickly that failures were very unusual; he's sending me a seal kit at no charge. His customer-service is tops and to be fair, I haven't been able to find any other reports of failures of his products. I accept that this failure is rare and might have occurred because the bike sat unused for many months, so I've bought a replacement slave as well, just in case there really is something irrepairably wrong with the original.
    No connection to the company other than as a pleasantly surprised customer with a swiftly and fairly sorted problem.
    Aut viam inveniam aut faciam
