how often does it need changing is there a post on here on how to do.
cheers murf.
cheers murf.
In your manual it says every 2 years. I kinda follow that. I know that others push it farther. There are some that would say: "Change what????........forks have oil????" and they never have a problem for years....
2006 Caponord - Rich's custom seat, drilled stock pipes, Catfish "429" map, Braking wave rotors, Rally Raid Bars/fender, Ricor Intiminators, Skidmarx custom windscreen ( propane torch special), Bags Connection tank bag
2004 Moto Guzzi Breva 750ie
Dude theres shit loads on here, have a search....?
Brum Brum
tracked some down there 150 euros a set ,went to buy some to copy there for radial calipers only!!!!!! the search continues,found the fork post with some diggin,mine was last changed 2 years ago ,so nnext job on list!!!!.
cheers murf.
Lurking with interest on the caliper brackets..
Seen them on ebay before. A tad overkill on the capo maybe.
On the fork goo, be aware on the manuals inconsistency on air gap.
Seeing as how you'l be in there consider some widgets http://www.apriliaforum.com/forums/s...inators&page=5
They work.
Brum Brum
do you have these fitted,been through all the service docs and have found that I have hagon uprated springs fitted and the kind chap gave me some oil as wellin spares kit,can i order them,also sourced some aluminium plate for brackets. found a machine shop too ,keep you informed.
cheers murf.
Yep, shock too, big improvement. http://store.ricorshocks.com/SearchResults.asp?Cat=55 They would work with your hagon springs too.
Brum Brum
