Results 1 to 15 of 19
Thread: Hard bags / trunk for newer Tuonos?
    apriliaforum newb typo's Avatar
    Nov 2009
    Does anyone know of any hard bag / trunk options for a 2007 Tuono? I've looked around quite a bit, and can only find options for the pre-2006 models. Givi doesn't make anything (called them).
    Sep 2009
    South Florida
    I'm looking into doing my own, at least for a hard trunk.
    Givi makes a mounting plate, a spare seat is cheap. Build some mounts off the seat from threaded dowels and a piece of 1/8" aluminum plate drilled to accept the Givi mounting plate. Voila! A hard bag mount that is detachable in seconds and can be switched from either a passenger seat or the cowl, all with the ignition key. A more robust system would include a brace down to the silencer mount at the cost of a bit more time/energy to make the swap.
    Swim upstream in life, only dead fish go with the flow.
    Ed
    apriliaforum Member siktuono's Avatar
    Jun 2008
    Grand Haven, MI
    here ya go...perfect
    Dec 2008
    I have a Marsee, that is rigid and large enough for a weeks worth of stuff depending on how you pack. They also have a smaller one that is good for over nighters or a daily bag to go to work. I have always had good luck with their stuff.
    http://www.marseeproducts.com/
    Steven
    10 RSV4 Factory.
    www.leanangleperformance.com
    Sep 2009
    South Florida
    For a short trip, eg 3 day weekend, I use a Givi Voyager tail trunk. It has a 2" wide Velcro strap that will slip under the pillion seat. It comes with a pair of small bungee cords that criss-cross underneath for stability but, the little hooks scratched the snot out of my rear bodywork. I replaced them with some small ROK straps and no problems.
    Easily holds 3 or 4 days worth of stuff, including my little Toshiba netbook and a Nikon D90 with lens. Supplement with a small tank bag and I'm good for a week or more, which means I can go for a month or more so long as the weather remains consistent.
    Ed
    apriliaforum expert twin4me's Avatar
    Jun 2004
    Nurburgring... been, there, done that, got the sticker
    Sorry but if you want hard luggage then you should really consider a Goldwing or BMW
    You can then store and tow everything you might need.
    I hear they wheelie well though
    You really only need three things for bike maintenance
    If it moves and it shouldn't - Duct tape
    If it doesn't move and it should - WD40
    ...and if it falls off and you want to reattach it - Cable ties.
    apriliaforum Member T1000's Avatar
    Nov 2007
    Alberta
    Hey SikTuono---- LMAO!!!!!!!!
    D
    In Garage now..
    Tuno 07
    Honda RC51
    Honda 954
    06 Kawai zx14
    04 Yamaha FJR
    Sold..
    Ymaha V-max
    Yamaha FZR 600
    Honda CBR 600
    apriliaforum Member manxkipper's Avatar
    Aug 2009
    Cape Town
    hard box luggage
    I am in the process of sorting out a rack - read 5mm alloy plate system on my Tuono for a 35l Givi top box fitting in place of the passenger seat. Bolted down so no issues with safety. I have done same for 2004 R1 and 2007 Fireblade. Works well but no place for passengers! Wife doesn't like bikes anyhow. As soon as I have it operational I will do the pics thing.
    2007.5 Tuono
    1961 Norton 500
    1969 Norton 650
    1981 Moto Guzzi LM 2
    Dec 2004
    Bend, OR USA
    I just put a GiantLoop Great Basin bag on my Tuono to get ready for a trip next month. It seems like it's going to be a deluxe solution for luggage on this bike. Easy on, easy off, and the space in side is cavernous compared to other systems I've used. It sits very securely and you don't even know it's there. Plus it has special spots sewn into it for carrying the MSR fuel bottles that I always need anyway on long trip to extend my range
    http://www.giantloopmoto.com/product...asin-saddlebag
    Here is it loaded up for a test run.
    Right now I just have the rear ties looped over the license plate bracket which is probably fine since they are only to keep it from sliding forward. My old bags looped over the indicator stalks and never had a problem even though they were actually securing the load. Still, I may add some D-Rings to the bungie hook bobbins back there.
    apriliaforum Member PdxTuonoR's Avatar
    Nov 2008
    Portland, OR
    That looks sweet! How many days can you pack up in there? I'm planning what I hope to be a 2-3 week trip this summer (if I can get the time off work), and need a good luggage solution.
    T
    Dec 2004
    Bend, OR USA
    Quote Originally Posted by PdxTuonoR View Post
    Pdx - I'm not really sure. It all depends on how you pack, I guess. My normal trips aren't as long as that but this is larger than my old Cortech luggage. And the internal space lets you pack larger things than the small individual side/top bags.
    Aug 2009
    Cape Town
    I made this plate to fit a Givi top box in place of the passenger seat. Two posts at the front and two c sections in alloy to slot over the frame tube at the back. Seems quite sturdy.
    2007.5 Tuono
    1961 Norton 500
    1969 Norton 650
    apriliaforum Junkie Aussie Factory's Avatar
    Jan 2010
    AUSTRALIA
    Quote Originally Posted by siktuono View Post
    apriliaforum Junkie arshishb's Avatar
    Aug 2007
    Edison, NJ
    Quote Originally Posted by manxkipper View Post
    Can you post a picture of the bottom of this? I am curious to see how you fabricated the mounting.
    01 Red Futura with euro black/gray tank AKA "Red Gremlin" - SOLD
    Will be missed
    Sep 2009
    South Florida
    My ultimate solution is just put the Givi bags on my Sprint ST and use that for long trips. Packing the tail trunk and tank bag would actually get me on the road for as long as needed on the Tuono. I have clothing that will dry overnight hanging in the shower of a hotel room, no need to pack more than 3 days worth and a bottle of Woolite. I will say the Sidi Vertigos and pants with zip off legs make an unusual fashion statement.
    Ed
