Page 1 of 4 123 ... LastLast
Results 1 to 15 of 60
Thread: Fuel Filter replacement, step by step
    apriliaforum expert pdxmille's Avatar
    Sep 2008
    Portland, Orygun
    So since I am replacing my tank with an 03 Tuono one, i thought I'd replace the fuel filter as well. I asked Chris if the fuel filter had ever been replaced, and he said no. Soooo, thought I'd replace. Didn't want to spend $50 on the Aprilia one, so off to Napa to pick up their Napa Gold fuel filter, model #3012, a stainless steel hose clamp for the ground, and some new spring clamps...
    first remove this clamp....
    then remove the filter ground...01-02s dont have this...
    Then remove the lower clamp...
    if you can remove these clamps without damage, I'll be impressed. I didnt reuse them....
    here are the filters side by side....
    as you can see, the napa filter is a wee bit smaller, but thats okay, as its soooo much cheaper you can replace it more frequently....
    Next is a shot of the filter removed...
    as stated, i removed the old clamps and replaced them...
    first I used a new spring clamp for the bottom...pay attention to the direction of fuel flow marked on the filter...arrow points down toward the tank base plate...
    then take the size 24 stainless steel hose clamp and place it over the filter....insert the ground wire between the clamp and filter housing, then tighten the clamp down nice and snug....
    thanks to kzmille for this idea....
    Now, use a new clamp and slide the top hose onto the filter...its a tight fit, but she slides on there!
    check the tightness of all the wire connection while you're in here...a couple of mine were a little bit loose...
    here's the tank cleaned up before going to the painter...
    then you're done with this part...i'll add to this when i get the tank back from the painters, and I'll do a step by step of mounting the fuel pump back into the tank
    hope this helps some people....
    Brad B.
    2006 ZX14 ***SOLD****
    2000 RSV Mille,***SOLD***
    Sweden, Linköping
    Sorry, but I would never use a spring clamp for that application.
    apriliaforum newb Gringo's Avatar
    Feb 2010
    Texas
    Wow, what a detailed post
    Awesome.
    Oct 2003
    NUNYA, USA
    Exclamation
    PDX -
    Agreed with deefred -- you shouldn't use "spring" clamps or even worm drive clamps on the HP lines inside the fuel tank.
    Check-out this post:
    http://www.apriliaforum.com/forums/s...highlight=fuel
    Read the whole thing -- it'll explain EXACTLY why NOT to do what you're doing.
    I'm in the process of replacing mine too -- and I've managed to amass all the necessary parts to do it properly the FIRSt TIME....except i'm not replacing my hoses. --judgement call--
    PM me if you have ??'s -- be glad to share what other members have shared with me!
    gr
    Sep 2008
    Portland, Orygun
    I have been using spring clamps in my current tank for over a year now with no problems....
    How about this?
    "Please feel free to use whatever clamps you feel like using. Everyone has an opinion on clamps, and everyone will tell you that the clamps THEY use are the best. Soooo, use whatever clamps you wish to use."
    There, is that better?
    Brad B.
    Oct 2003
    NUNYA, USA
    Hey, sorry dude.
    Just didn't want you to suffer the "exploding" fuel line syndrome as some others have.
    I personally didn't want to chance it -- but that's just me.
    gr
    %@*#&! hank's Avatar
    Earth
    One the the better write-ups on this.... might be worthy of making it a sticky and moving over to the 1000cc FAQ section...
    I'll probably move over the Sprag clutch change thread to the 1000cc FAQ section as well...
    Sep 2008
    Portland, Orygun
    I'm not upset at all!
    I am saying that there are literally several different clamps that can be used without any negative effects...I read the thread posted above...and I am not gonna buy $60-$80 worth of clamps and a special tool when I have found that the way I do it works just fine....
    Hence, I was saying, please feel free to use whatever clamps you like!
    No worries!
    Brad B.
    Oct 2003
    NUNYA, USA
    I got a little bugged-out when i saw Wavz's post of the drive-clamps tearing-into the hose....
    I was able to bum a few Oetiker clamps off of another member, and still need to buy some pliers -- but for me, I needed the piece of mind.
    I really don't want to have to find-out the hard way, that this assembly has come unseated in the pump/tank. Hence....
    He suggested I replace my hoses too -- but mine look absolutely fine.
    i DID buy some Permatex Anaerobic gasket sealant (loctite 518) to seal the o-ring...but that was enuff for me.
    Good pics - good post.
    gr
    Sep 2008
    Portland, Orygun
    When I first redid the fuel lines in my current tank, one hose did slip off while I was riding the bike. I took the pump out and looked at the hose. Turns out the hose, after being submerged in gasoline for awhile, DOES soften up, hence what was a perfectly tight connection when installed, becomes looser after the hose softens up...reinstalled the hose, tighten the clamp a little tighter, and i haven't had any problems since then! and remember, I was using the Gates $28 a foot submersible hose and it softened up after a while in the tank...
    i love learning all the little tricks about this bike..its fun!
    Brad B.
    Oct 2003
    NUNYA, USA
    Quote Originally Posted by pdxmille View Post
    So - it was a NEW Fuel line that softened-up?!
    Sep 2008
    Portland, Orygun
    Quote Originally Posted by ghostrider71 View Post
    correct! NEW $28 a foot Gate submersible fuel hose....it softened up a LITTLE bit, not like it got all spongy or anything....just enough so that my perfectly tight fuel clamp on the hose now wasn't tight enough....retightened all the connections when I was reinstalling the fuel line that popped off, and no problems since....
    Brad B.
    apriliaforum Junkie gweedo's Avatar
    Cornelius OR
    Brad, I still need to redo my clamps in my tank.. and I got all the stuff for the decals also..
    Sep 2008
    Portland, Orygun
    Quote Originally Posted by gweedo View Post
    no problem....Ill come over this week and we can get her done!
    Brad B.
    Jun 2006
    Columbus, GA
    Added
    2007 Tuono 1000R Factory
    Cored OE Racing CansMap2Pazzo Knock-offs15-40AF1 Link PlatesAprilia Sliders
    ProTaper Mini-LowClear Signal Lenses
    Retired - DJ, Turntablist, Creator and Mixologist.
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
