Page 5 of 6 FirstFirst ... 3456 LastLast
Results 61 to 75 of 86
Thread: BMW and third party parts for Pegaso
  1. #61
    Chicago, US
    Few other Ferodo PN's also fit, but these are most common:
    Ferodo Front Pads FDB2006ST
    Ferodo Rear Pads FDB314ST
    (AF1 was also selling these in the US)
  2. #62
    apriliaforum newb Leif's Avatar
    Jan 2012
    Denmark
    need to replace a broken Oliespringring (2.5 mm) pegaso 650 97 engin, piston 100-6++ made i austria ELKO 1992 99,97 AB.
    Can you help with a link or a sparpart?
    Best regards and happy newyear to you.
    e-mail: kopi-maskiner@stofanet.dk Leif Højklint
  3. #63
    Chicago, US
    Quote Originally Posted by Leif View Post
    Can you help with a link or a sparpart?....
    Piston Ring Set only (all 3 rings) 99,97mm
    AP0295184 for engines up to No. 635617 US$120
    AP0295984 for engines from No. 635617 US$150
    Not sure if you can buy individual rings, however I think if you are replacing the oil ring,
    might as well replace the rest.
  4. #64
    Jan 2012
    Denmark
    Pegaso 660 motor 1997 no.: 6211265 piston: ELKO 1992 og 99.97 AB.
    1.5 mm 1.2 mm Oilering 2.5 mm !! AP0295184 PISTON RING SET - UP TO ENGINE N. 635617
    Older donor motor. Pegaso 660 1994 piston: GILARDONI
    Oilering 3.0 mm !!!
    I will remove 0.5 mm from the piston and then use til 3.0 mm ring i already have
    set off new AP ring kost 85 £ i UK - BMW F 650 ring set ENA 43266 45£
    lot´s off sparepart from the old Aprilla Pegaso 1994 - motor , cab, CDI + aske :-D)
  5. #65
    Mar 2010
    Germany
    Hello Leif,
    did you bought your bike from Johnny C.C. Wind (Blaest77)?
    Regards from Germany,
    Holger
  6. #66
    Jan 2012
    Warwick
    Quote Originally Posted by somclan View Post
    Will fuduro water pump fit a cube peg ?
    Anyone able to anser this? Kits for f650 are £25 on ebay, can't find Pegaso one (Ihave water leaking from weap hole, oil in water and water in oil!!)
    As no one replied, I took a flyer and bought a F650 water pump repair kit. I can confirm they are exactly the same and real easy to fit. It could have been worth just buying seals from a seal supplier for a few pence as there was nothing wrong with the spindle.
    There was a heck of a lot of water in the oil when I drained the frame tank and the water bottle has a nice oily covering!
  7. #67
    apriliaforum newb samuraijmb's Avatar
    May 2011
    Northern Ireland
    Hi Guys,
    My 1997 Pegaso Cube has recently developed a hole in the very crappy mild steel exhaust. I am in the process of fitting Motad Venom Stainless Cans (£295 which isn't bad) from these guys http://www.modulemoto.co.uk/ based in Northern Ireland - They are not on the website, I had to call.
    The predicament that I am in is that I cannot find anywhere a stainless steel front pipe. I know that when put the new exhaust on that it will probably start to weaken the front pipes more so would like to change them. If anyone knows where I could pick a stainless front pipe up it would be greatly appreciated.
    Cheers
  8. #68
    apriliaforum Member koukosnest's Avatar
    Oct 2007
    Greece
    All i want from my birthday is another birthday!
  9. #69
    May 2011
    Northern Ireland
    Hi Koukosnest,
    Yeah I saw those but i am really looking for stainless steel pipes as I ride all year round and the weather is not kind to the mild steel oem parts.
    I contacted Motad but they only do the cans and link pipe for my bike which i have ordered.
  10. #70
    apriliaforum newb lvdxd00's Avatar
    Jul 2008
    Wirral
    Hi all
    I am after a clutch for my 1995 650 peg.
    will the f650 one fit?
    cheers
    Dave
  11. #71
    apriliaforum newb kapcom's Avatar
    Jan 2012
    san antonio, texas
    My bike 2000 Pegaso 650 Cube. Third party parts are Starter from 2000-2007 Bombardier DS650 ($90.60 new with free shipping from Ebay) and Sprag Clutch from KTM Motorcycle Part #58440026000 Freewheel FWD332008BLS ($60.08 from powersports warehouse). Happy motoring.
  12. #72
    Chicago, US
    Yes it will. P/N 11512343451 and it comes assembled (impeler on the shaft and two seals).
  13. #73
    Portsmouth, England.
    Fuel Level Sensor
    I found AP8124437 (fuel level sensor) for just under £30, including VAT and delivery (UK) at these people -
    http://www.apriliapartsonline.co.uk/..._cock_628.html
    I only ordered it today, so the jury is out on whether they can deliver it quickly, but they do seem cheap.
    I was going to order it from Yorkshire Aprilia (about the same price), but they're server seems to be playing up :-(
    Some of the other sites I looked at wanted between £60 and £80, for the same part.
    Rob
  14. #74
    May 2012
    London
    Hiya, new to the forum...having a nightmare for so long with a pegaso Ie 2001, can anyone confirm the bmw or ktm alternative sprag for these? also does anyone have the starter gears for the IE? I think mine will be messed up by now!
    NMN
  15. #75
    May 2012
    London
    what about sprag gear for pegaso ie? any cheaper alternative from other makes guys? grazie
