Results 1 to 6 of 6
Thread: Ventura Rack Question - 2008 R
    apriliaforum Member jhawkinsvalrico's Avatar
    Nov 2009
    West Central Florida
    I believe that I know the answer to this, but want to check before I order a Ventura rack system and find that it doesn't fit my 2008 R. Returning stuff sucks.
    When I go to the Ventura website and choose Aprilia, the site offers Tuono 2006-2007. Am I correct that the 2008 T's frame is the same as the 2006-2007 and Ventura just haven't updated their site?
    Thanks - as I said above, ordering and having to return it because I screwed up and didn't check sucks.
    2008 Blue and White Aprilia Tuono R
    2006 Caspian Blue Trumph Sprint ST
    2009 Jet Black Triumph Street Triple
    apriliaforum expert Unreal's Avatar
    Oct 2007
    SLC, Utah
    Yep, no difference. You'll be fine.
    Nick
    06 ZX6R
    07.5 Tuono
    Kansas City, MO
    Nov 2009
    garrettg, pm sent.
    apriliaforum Member Gone_Ape's Avatar
    Jul 2008
    Austin TX
    I have the Ventura rack with the low "sport" rack option....as I use my bike to commute daily, it's invaluable. Couldn't warm up to the taller racks size though.
    I didn't buy any of the bags as I use my own stuff I already had.
    The rack comes on and off VERY easily in 5 minutes or less. The only oddity I found was it did not line up exactly the first time I installed it. So I left all the fasteners loose as I assembled and then secured everything down proper. I still wasn't satisified as one of the supports came very close to fouling the left turn signal lens. Out came the 1/2 inch drive socket extension bar and with a little bend it now it fits perfectly.
    Mind the powder coat.......it apparantly scratches pretty easily.....as me how I know...
    07 Tuono R / Black
    Austin, TX
    Nov 2009
    Gone Ape, Thanks for the installation tip. I picked up a used rack (complete system) from another forum member. Now I need to research gas caps so that I can install a SW-Motech mount on the T so that I can use my Bags Connection tank bag on this bike. It sounds like the yoyodyne cap might work - need to get specs from yoyodyne and then check with twisted throttle. I'm a little put off with the price of the yoyodyne, so I might search for a less expensive gas cap. I'm a bit concerned that cheaper might mean cheaply made and will leak.
