Page 5 of 7 FirstFirst ... 34567 LastLast
Results 61 to 75 of 93
Thread: Carbon fiber intake trumpets
  1. #61
    apriliaforum Junkie Cyber's Avatar
    3rd rock out
    Feedback Score
    7 (100%)
    so on a 2008 tuono, what is the actual gain I would see on a dyno with the trumpet install with the bike already on map 2 with akro cans on it?
  2. #62
    apriliaforum prov-nov stepesenti's Avatar
    italy
    Feedback Score
    3 (100%)
    Quote Originally Posted by Cyber View Post
    This is a bench test with trumpets and power commander
Name:	57x70 duali mappa ottimizzata.jpg
    made by stefano from italy+=
  3. #63
    apriliaforum Junkie Cheesy's Avatar
    Oct 2005
    Rutland, UK
    Feedback Score
    0
    I'd like to order a set of the dual 57's please
    04 Tuono Fighter
    Soon to be Running Gen2 1060 Engine
    With the Help of Gabro's Chip
  4. #64
    italy
    Feedback Score
    3 (100%)
    Quote Originally Posted by Cheesy View Post
    ok I have sent you a private message with instructions
  5. #65
    Oct 2009
    Feedback Score
    0
    what airbox you going to run them in chris?
  6. #66
    3rd rock out
    Feedback Score
    7 (100%)
    I'm intested but have a few questions, your showing a 6.5 hp increase but with a power commander, i don't use a power commander , will i see a 6.5 hp increase?
    is that the single or dual one used?
  7. #67
    italy
    Feedback Score
    3 (100%)
    of course, the performance increase is proportional.
    trumpets duals also work with original engine, about 3 hp increase.
    the advantage is migior a function of the air flow sucked and a linear power delivery over the entire operation range.
    I use on my Aprilia trumpets duals with original engine
  8. #68
    Sep 2013
    Nevada, USA
    Feedback Score
    1 (100%)
    Installed the dual trumpets on my '07 Tuono. There's an obvious subjective improvement in midrange punch, and the upper range (above about 7k or so) is *really* noticeable compared to the stock (long) Tuono stacks. My bike is not heavily modified, OE Akras with cats, no inlet snorkel, DNA filter, and "map 2".
    The whole range just feels better, throttle response is improved (it was generally good, but felt a bit soft (rich) here and there before), it's more "lively". I have no reason to even consider custom mapping, it's perfect enough.
    I don't have a modified airbox, and had to carefully trim a small section of the large lower trumpet to clear the stock breather. The breather works fine here, no oil in the airbox or any other problems, so I left well enough alone. It took some time to get things fitting perfect.
    I realize this isn't a scientific endorsement, and while I wouldn't expect much change on a dyno, the character of the engine has changed for the better. Well worth the effort, highly recommended.
  9. #69
    May 2016
    Rockford
    Feedback Score
    2 (100%)
    I'm in
    I'd like to order this, please PM
  10. #70
    italy
    Feedback Score
    3 (100%)
    you have mp
  11. #71
    apriliaforum prov-nov fsr's Avatar
    Spain
    Feedback Score
    0
    Quote Originally Posted by stepesenti View Post
    you have mp
    and you
    thanks
  12. #72
    May 2013
    greece
    Feedback Score
    0
    Hi stepesenti,you are stefano from apriliagarage?
    I sent you a email there.
    I'm interested about the duals 2.
    Please contact me.Thanks
    George
  13. #73
    italy
    Feedback Score
    3 (100%)
    Hi yes I'm Stefano.
    I reply on apriliagarage
  14. #74
    apriliaforum newb Chris_RSVR's Avatar
    UK
    Feedback Score
    0
    Edit - Sorry maybe next month just looked at the bank balance
    Chris
  15. #75
    apriliaforum expert lospsi's Avatar
    Jan 2004
    Athens, Greece
    Feedback Score
    0
    Chris
    The same thing happens to me all the time
