Results 1 to 15 of 15
Thread: Shocked
    apriliaforum expert MJPacheco1's Avatar
    Sep 2009
    Laguna Beach CA
    Shocked
    I see that Aprilia makes a aftermarket shock upgrade for the R Factory.
    Is this a good investment, or are there even better upgrades??
    Michael
    Parker Colorado
    It's a good 2 up shock or if your over 250 pounds. Other than that it is way too stiff even on it's softest setting.
    apriliaforum Member redsr50's Avatar
    Aug 2009
    milwaukee
    i was also looking into this as well. i only weigh like 135 or so....so i shouldnt be investing in this then? ha ha
    Apr 2009
    DFW Texas
    I weigh 135 as well, and am interested in this shock, but maybe highgain knows of a more suitable alternative.
    Sep 2008
    Nice weather AT LAST! Winnipeg, MB
    Quote Originally Posted by redsr50 View Post
    Quote Originally Posted by alex98098 View Post
    The shock is listed as a "Racing Shock". I believe that there are other aftermarket shocks out there; you just need to search the various on-line Scooter stores.
    Having said that, I have the racing shock and I love it. My weight moves between 200 and 215 (not including what ever I have in the Helmet well or the Top Case) and I find that I like the idea of adjusting the shock based on the road conditions. I also think it looks sharp!!
    Anger is an ugly Mistress…
    apriliaforum expert DJ GT-S's Avatar
    May 2008
    Quebec City, Canada
    I'm 180lb, ride alone and I've got it on the 3rd notch, which i feel is perfect. When I sit on the bike, both the front and rear compress by the same amount, and when i drive over bumps, they "feel" the same though my hand and through my butt.
    And that's just the spring rate. The dampening is also much better, which is immediately noticable if you enjoy some spirited driving on twisty roads and often find road imperfections in your way.
    Back with with 400% more cubic centimeters!
    2010 Yamaha WR250X
    Former owner of a 2006 R Factory Morini Ditech
    Designated mechanic for a purdy '11 Alitalia rep
    Parker Colorado
    I would like to bring in and try the Malossi RS24/10 and the less expensive Malossi RS3
    apriliaforum expert MeepMeep's Avatar
    Jul 2008
    Mass
    I have the shock HG shows above. it came with a spanner to adjust. that little black piece on the bottom also clicks each turn but even after reading im not sure what exactly its adjusting.some kind of fine adjusting it seems. the malossi english translations arent the best this one is for the PPJ. it was a little more but the aprilia only has 4 settings. i think this is fully adjustable. i dont know as much as i should, but im gettin there
    2009 SR50R Factory diablo white
    Currently getting the HGT replica WORKS!
    2002 SR50 Ditech Haga SBK replica
    70cc malossi BBK w/ecu
    blue aprilia 7075 ergal bolt kit
    blue aprilia 7075 ergal bar ends
    malossi delta clutch
    malossi reed block
    Aprilia Paoli adjustable shock
    Installed Pussy Magnet
    Apr 2009
    DFW Texas
    Quote Originally Posted by MeepMeep View Post
    I have the shock HG shows above. it came with a spanner to adjust. that little black piece on the bottom also clicks each turn but even after reading im not sure what exactly its adjusting.some kind of fine adjusting it seems. the malossi engnlish translations arent the best there are more pics in my post "shes finally back" this one is for the PPJ. it was a little more but the aprilia only has 4 settings. i think this is fully adjustable. i dont know as much as i should, but im gettin there
    probably adjusts rebound or compression damping maybe both. At least that's how it is on my car shocks.
    Parker Colorado
    Looks awesome on your scoot with all the white
    Jul 2008
    Mass
    mine is a litttle different. if you compare mine to the sip pic it obviosuly doesnt have the gas thing but it does have the adjustable black thing that the rs3 is missing. i thought i got the ppj rs24 but now im not sure, ill have to look
    thx HG!
    malossi reed block
    Sep 2008
    It looks great!!
    I'm just not a big fan of that purple colour...
    Do they have colour options?
    May 2008
    Quebec City, Canada
    Usually, when there's only one adjustment on a shock, it's compression, so as you crank the knob, it should become stiffer and stiffer on the compression stroke.
    2010 Yamaha WR250X
    Sep 2009
    Laguna Beach CA
    I love this shock. Where di you purchase it??
    Sep 2009
    Laguna Beach CA
    As soon as I see them on the site, I will order.
