Results 1 to 13 of 13
Thread: Shim Guide for Tuono and RSV(R)
    apriliaforum Junkie zlionakis's Avatar
    Oct 2006
    Greece-Crete
    Hi to all,
    I have recently completed a valve clearance check and adjusting for my bike and was so pissed off to have all these papers and calculations to deal with (records and calculations) in order to find the appropriate shims.
    Thus I decided to designa spreadsheet to easily note/calculate the clearances and shim sizes needed for my motor.
    Moreover, because in some shops you cannot get hold of the shims that you actually need I have implemented a way of calculating the next possible shim for your bike.
    You can download it from my link below
    Any feedback to improve the current sheet is appreciated.
    Hope you enjoy!
    Zac
    Attached Files Attached Files
    If you don't fall.....you don't Learn!!!
    Honda VFR 400RZ/1988
    Cagiva Canyon 600/1996
    Honda CBR 600F2/1993
    BMW R1200GS/2005
    Aprilia SXV 550/2006
    Honda CRF 250R/2006
    Aprilia Tuono 1000R/2008
    Aprilia Sportcity One 125/2010
    KTM 570SXS/2008
    If you can get hold of a Suzuki TL1000R shop manual have a look at it. It has a wonderful chart that does exactly what you want. Doubt the numbers will work for the Rotax but you can see a good way to set it up.
    apriliaforum Member Gone_Ape's Avatar
    Jul 2008
    Austin TX
    Nice, very nice......this I can use (and very soon)...Thank you !!
    07 Tuono R / Black
    Austin, TX
    Oct 2006
    Greece-Crete
    Did not have seen it until now, but after a web search I was able to download it.
    Indeed it is a very handy diagram that uses a different resolution of measured tappet clearance for intake and exhaust sides.
    Could be implemented with the aprilia shims but it needs a bit of work!!
    BMW R1200GS/2005
    Honda CRF 250R/2006
    KTM 570SXS/2008
    Post it up if you can.
    Oct 2006
    Greece-Crete
    There you go,
    the TL1000R intake
    and exhaust
    BMW R1200GS/2005
    Honda CRF 250R/2006
    KTM 570SXS/2008
    Thanks. It will be interesting to see if it can be adapted to the Rotax.
    I don't get it, what is the purpose of this chart?
    I've been adjusting V990 valves for many years by simply measuring the clearance on each valve and writing those numbers on a piece of paper.
    I then compare the measured values to the desired values and determine how much thicker or thinner the new shim needs to be to achieve correct clearance (basic math, add or subtract).
    At this point it is a simple a matter of removing the old shim, measuring it and substituting an appropriately thicker or thinner one (based on my simple math).
    As you know, shims are available in .025mm increments (.001").
    The shims are listed in the manual by order of p/n, not in order of size.
    re-arranged by sizes:
    0253974 - 2.300mm
    0254030 - 2.325mm
    0253975 - 2.350mm
    0254031 - 2.375mm
    0253976 - 2.400mm
    0254032 - 2.425mm
    0253977 - 2.450mm
    0254033 - 2.475mm
    0253978 - 2.500mm
    0254034 - 2.525mm
    0253979 - 2.550mm
    0254035 - 2.575mm
    0253980 - 2.600mm
    0254036 - 2.625mm
    0253981 - 2.650mm
    0254037 - 2.675mm
    0253982 - 2.700mm
    0254038 - 2.725mm
    0253983 - 2.750mm
    0254039 - 2.775mm
    0253984 - 2.800mm
    0254040 - 2.825mm
    0253985 - 2.850mm
    0254041 - 2.875mm
    0253986 - 2.900mm
    0254042 - 2.925mm
    0253987 - 2.950mm
    0254043 - 2.975mm
    0253988 - 3.000mm
    Oct 2006
    Greece-Crete
    0253974 - 2.300mm
    0254030 - 2.325mm
    0253975 - 2.350mm
    0254031 - 2.375mm
    0253976 - 2.400mm
    0254032 - 2.425mm
    0253977 - 2.450mm
    0254033 - 2.475mm
    0253978 - 2.500mm
    0254034 - 2.525mm
    0253979 - 2.550mm
    0254035 - 2.575mm
    0253980 - 2.600mm
    0254036 - 2.625mm
    0253981 - 2.650mm
    0254037 - 2.675mm
    0253982 - 2.700mm
    0254038 - 2.725mm
    0253983 - 2.750mm
    0254039 - 2.775mm
    0253984 - 2.800mm
    0254040 - 2.825mm
    0253985 - 2.850mm
    0254041 - 2.875mm
    0253986 - 2.900mm
    0254042 - 2.925mm
    0253987 - 2.950mm
    0254043 - 2.975mm
    0253988 - 3.000mm
    Firstly the aim of this spreadsheet is to help the user to note the clearances and current bike shims easier by organizing the view layout and without the need for any papers..(ofcourse you can make a printout if you wish)
    Then by using simple math formulas it calculates for you the shim that you need to place on any valve as long as you give the necessary info (i.e. current clearance and current shim size)
    Finally the result has to be rounded by the user to the next 0,025 increment. I uploaded a V2 of the spreadsheet that does it for you!!!
    And also it calculates the clearance that you will have with a different size shim at the bottom of every box....(simple maths as well!)
    Though everything is simple, it takes some time to organize your thoughts and pen in order not to make any mistakes...My aim was to make things easier by using this sheet which in my opinion helps both taking down your notes and values and calculates the results for you automatically.
    Moreover, it is very easy to have your bike's valve clearance history if you wish so you will now next time what shims are in your bike without taking apart your cams...(plus you can do that for a limitless number of bikes)
    Finally, it is not compulsory for one to use this sheet....Everyone has his own way of doing things..If on the other hand one thinks that it is of good use , it is here already made for and free..
    BMW R1200GS/2005
    Honda CRF 250R/2006
    KTM 570SXS/2008
    OK, fair enough.
    Here is Aprilia's valve log sheet that has been out since 1998.
    Oct 2006
    Greece-Crete
    OK, fair enough.
    That is very nice, did not know they had something like this and did not have it in my hands...That is why I came up with the spreadsheet...
    Only minus....it does not do the maths for you!!!
    BMW R1200GS/2005
    Honda CRF 250R/2006
    KTM 570SXS/2008
    I do my own math, much quicker then a calculator or computer spreadsheet for such simple numbers.
    Besides, in the real world of fumbling with oily shims, my oily fingers sometimes slip on the keyboard and I end up with the wrong numbers
    apriliaforum expert derbybrit1's Avatar
    Feb 2005
    San Dimas, CA
    Quote Originally Posted by zlionakis View Post
    Zac
    I am using Excel 2003 SP3. The Red cell for 'New Shim Size' is not calculating. It has #NAME? or #NUM! in those cells, and does not calculate when I updated the Green cels with Measured Clearance and Measured Old Shim.
    I can audit the formula, but since the sheet is locked I cannot widen the colum to see the whole formula. It looks like:
    =MROUND((C7+C11-C9)
    Is there a bracket missing? How about giving the unlock password so it can be fixed or enhanced?
    Thanks.
    Team Punisher/AF1 Racing:
    World's Fastest Aprilia RSV 200.8mph
    Texas Mile Record Holder - Fastest Twin
    Aprilia Testimonial:
    I'm riding the same roads I've ridden for years with pace and conviction that belies my relative lack of talent.
    --SlamDunK
