So,
My Friend has an 09 SR50R as do i, and his keys open all my locks and turn on my ignition and even start my scoot. but mine dont work with his. pretty weird stuff, i would expect better from Aprilia.
Just thought I would share.
So,
09 SR50R Carb. All stock for now
You can cut a key only so many different ways.
Apparently the 'immobiliser' is not working. I would take it to Aprilia.
2006 SR50 Factory (morini) Aprilia Black
ECU V2.82 Derestricted 6.8g rollers
Completely stock - bought at 1400km after bearing failure on other bike
Currently over 3700 KM - Parked for winter
2006 SR50 Factory (morini) Orange - Wearing Spiderman 2 Costume
ECU V2.82 Derestricted, 7.2g rollers, ZMR7AP plug
One HID Headlight (low beam), Clear LED tail light
Michelin Pilot Sport SC Tires w/Dynabeeds
Electric trunk release - way cool!!
Interstate IB9-B Battery
ACDelco / Schrader TPMS Sensors (Project In Progress)
AMSOIL HP Injector oil
All else is stock - over 32,500 KM
LEFT MAIN BEARING FAILURE AT 33,000km
Repairs and upgrades including HEL brake lines in progress
Ya, my father sold cars for over 35 years and use to keep any extra set(s) of keys that would sometimes come with them in a large box. They had tags on them that would say the year, make and model of car or truck on it. They would come in handy if the costumer lost their sets of key(s). But, on some occasions, if my father lost a key, or more often a key was locked in a car (that happened a lot after a test drive) and that was the only set of keys, he would go to this large box of keys and start to see if any would fit. And more often then not (like 8 out of every 10 attempts), he would find a key that would work.
HG probably knows the stats for GM, but there are only so many key combinations that a manufacture uses and if they produce several thousand makes each year, they are bound to have a few duplicates. Know multiply that by the number of years that that blank style is used and you get to see the picture. Especially if they, like the big 3 did, continue to use the same key blanks for so many years...
That is the one true advantage to the “chip in the key” that works on many immobilizer equipped vehicles. Sure you may find a key that may fit and even work the lock/ignition, but the chances that that other key would have the same chip code as yours is slim to none…
I didn't know that... I thought that all SR50's had the immobilizer in them.
Anger is an ugly Mistress…
Michelin Pilot Sport 140/60 Rear tire w/Dyna Beads & TPMS SensorMalossi 15/40 Primary Gears & Multivar w/4.4gr Dr. Pulley Sliders/Kevlar Belt
2001 SR50 Ditech (Morini)
31'220 km (engine 8070km)
Top speed : less than 80km/h (belt needs to be replaced)
7 gr. rollers & stock exhaust
Castrol TTS (fully synth.)
I use any type of fuel
But if his bike is a carb, his key shouldn't have the transponder chip, hence, your immobilizer should stop it from starting your scoot.
[edit]
Oh wait, because we're in the ditech section I had assumed your's was efi, I checked your sig and seems I was mistaken in my assumption.
Back with with 400% more cubic centimeters!
2010 Yamaha WR250X
Former owner of a 2006 R Factory Morini Ditech
Designated mechanic for a purdy '11 Alitalia rep
When I worked for Toyota years ago, each model had a 4 digit key code, so there were 9,999 possible key codes for each model. Of course, I don't know if they were actually cut 9,999 different ways.
My old '88 4Runner had it's ignition barrel so loose that the key would fall out while driving. Also, it could be started with any key... or anything shaped like a key... or not shaped like a key... Anything basically... It had a zillion key codes all at once ^_^
2010 Yamaha WR250X
I was with someone at a large shopping entre carpark some years ago and when she pressed the button on her key to unlock her car remotely another car about 20 feet away unlocked!! I swear thats the gods honest truth, something I would have thought unlikely to ever happen. Like what are the odds!?!?! long odds but very possible![]()
