Results 1 to 4 of 4
Thread: Rear shock question
    Dec 2003
    Elmont, NY
    Rear shock question
    my rear shock is on its way out (37k of carting my fat ass around did it in LOL)
    So I am thinking about replacing/upgrading and wanted some input on what others have. I see that I could go with an ohlins, a wibber or replacing the stock unit.
    Most of my riding will be commuting to work (through NYC so the roads suck) along with some weekend touring/canyon carving, and it seems the missus want sto do some more 2 up riding so I def will need a beefy rear spring (shes around 140 or so and i am up at 250)
    So any input would be greatly appreciated.
    Tom
    Apr 2005
    Are you going to insatall it yourself? I would go with Penske or Wilbers for a direct bolt on, but if you're handy you can try installing an Ohlins. Get a remote preload adjuster so you can easiliy crank it up when riding two up and then back down again to ride solo.
    Read... http://www.apriliaforum.com/forums/s...=169904&page=3
    - Sam Shepard
    -Neil Peart
    '02 Ash Black RST (w/ black wheels!)Stainedtunas,AF1 H-pipe,PCIII,EVO race airbox kit & filter, Mille intake boot, Tuono forks w/Ohlins revalve, Ohlins Rear Shock,Brembo 4 pad calipers and Radial Masters,(999) 320mm Sunstar rotors, Goodridge steel lines, Borella Reg/Rec w/silver solder crimp upgrade, R&G Frame sliders (one used), Zumo 550 GPS, Flux Capacitor, Hubcap Diamond Star Halo, Vintage BEF plate bracket, T'meisters, Michelin Pilot Road 2s,.
    2009 Ducati 848 track bike
    Carthage, NC
    I recently installed a Penske in mine....
    http://www.apriliaforum.com/forums/s...d.php?t=183918
    Ron
    MSgt USMC (Retired!)
    Semper Fi!
    Nesba A #45
    IBA #38812
    RST Futura
    RS50
    Dec 2003
    Elmont, NY
    Quote Originally Posted by The Fixer View Post
    Excellent points esp on the preload adjuster esp with the missus bugging me about more 2 up riding. I iwll be doing the install myself so I can use the links here as a guids to install what I get. I iwll research the penske unit and decide between that and the wilbers unit.
    Tom
