Page 6 of 21 FirstFirst ... 4567816 ... LastLast
Results 76 to 90 of 314
Thread: OEM manufacturers/suppliers
  1. #76
    Jan 2006
    Cheshire, England
    Iridium spark plugs IXU27-- £39.96 to your door!(for four!) www.opieoils.co.uk
    My local bike shops want £20 each!!!!!!!
    03 Capo
    K&N Air Filter
    Remus GP Pipes(Cats removed)
    Std Cat Map
  2. #77
    Jun 2004
    cornwall uk
    I think thats the part no for the Nippon Denso Iridium plugs . Thery are a lot dearer than The NGK ones .
    There is an NGK plugs online specialist , I got my iridiums for just over £30 I think .
    Exspert?? Ex = has been, spert = a drip under pressure.
  3. #78
    Jan 2006
    Cheshire, England
    Yes they are Nippon Denso. Who is the online specialist you use then??
    I've seen NGK's for the same price as the ND's.
    03 Capo
    K&N Air Filter
    Std Cat Map
  4. #79
    Jun 2004
    cornwall uk
    www.sparkplugs.com
    for iridium plugs for your capo.
    same plug is listed for all 1000 v twins.
    DCPR9EIX NGK IRIDIUM
    DCPR9E NGK STANDARD
    IXU27 DENSO IRIDIUM TWICE THE PRICE OF NGK
    This is a copy of an old post in the sticky post for parts
  5. #80
    apriliaforum Member geordielad's Avatar
    Mar 2006
    NORTHWALES UK
    [QUOTE=ian-parkes]www.sparkplugs.com
    www.spark-plugs.co.uk/
    for the same plugs in the uk, but instead of $6.95 in the states its £6.95 in the uk.
    tipical uk getting ripped off as usual
  6. #81
    Jan 2006
    Cheshire, England
    NGK's are £8.14 + vat at spark-plugs.co.uk This makes em' £9.56 each! Dunno where ya got £6.95 from! Mind you ND's are 11.38 + VAT!
    03 Capo
    K&N Air Filter
    Std Cat Map
  7. #82
    Mar 2006
    NORTHWALES UK
    sorry my mistake i looked at the wrong plug
  8. #83
    Mar 2006
    NORTHWALES UK
    barrac mirrors
    if you like the mirrors on capograndads bike heres the link
    http://www.barrac.it/prodotti_scheda_tecnica.jsp?id=20
  9. #84
    Jun 2005
    Reluctantly in W London, UK (really a country boy)
    Fenda extenda, fender extender, what you will...
    Pyramid plastics have just started doing a front mudguard extender for £17.99, ditto some bloke on ebay (same product). OK, so it's not going to set the world alight, but I've just got back from the pub, ok?....
    Matt
  10. #85
    apriliaforum Junkie Aregata4x4's Avatar
    GA
    The mighty oak tree was once a little nut that held its ground.
    ETV1000
  11. #86
    Cooma N.S.W.
    Anyone tried the K&N AL-1002 air filter that fits Capos??
    Also for Ozzies this may help...
    http://www.rycofilters.com.au/catalogue/
    JohnG.
    '02 Capo.
  12. #87
    Scottsdale, AZ
    Quote Originally Posted by northcape02
    Spark Plug Cables
    Caution, attached jpg is graphic and explicit in nature, and intended for mature gear heads only. Please escort small children outside before paging down.
    Had a problem with the number one wire at the coil end, this was the same coil that fired itself because of a loose wire. Donít know if the wire just got wet, or wrong type of grease was used on it, it did feel gooey. New wires go on and of easily (without pulling the boots back), with a reassuring click at the plug. Connectors are a little different, and I did take the precaution of strapping them down using two electrical ties at the coil end, and one around the porcelain at the plug. Been using them for over a thousand miles now and so far they havenít come loose.
    Got them here http://www.magnecor.com/ it took a couple of emails and a couple of phone calls, and I had them in hand in less than two weeks.
    There are several wire options available, I chose the KV85 8.5mm cables.
    Best Regards,
    Colin
    Where did you get the new brass terminal for the coil end of the wire?
    Stu
  13. #88
    Scottsdale, AZ
    CLIC clamp pliers
    I bought a set of KLANN pliers at a trade show last month - very expensive. Today, I found these pliers at a very reasonable price. They install AND remove the clamps.
    Clic clamp plier
    Even better tool
    This is an exact duplicate of the KLANN tool I purchased that retails for $75 US.
  14. #89
    Mar 2006
    NORTHWALES UK
    Check these out they seem to have most sundries for our machine + other bits http://www.bandcexpress.co.uk/index.html
  15. #90
    apriliaforum Member dan albertson's Avatar
    Sacramento CA
    How is the wind noise?
    Quote Originally Posted by lospsi
    Here's my Ermax screen.
    Good design, smoke color and discrit too! The noise still exists though
    I tried a Givi windshield and prefer the stock windshield with the Laminar lip. How is the wind noise on the Ermax, and on the Secdem, if anyone has any experience with them?
    Dan in Sacramento
    2003 Aprilia Caponord
    2006 Honda GoldWing
    2007 BMW R1200R
    2007 KLR 650
    2000 Harley-Davidson Road King
  1. Help: Photos of OEM Cup bodywork?
    By smcnamara in forum RS250
    Last Post: 03-08-2007, 02:14 AM
  2. Cheapest place for OEM brake pads?
    By TwinNut in forum SL1000 Falco Forum (all years)
    Last Post: 12-18-2005, 01:45 PM
  3. Are OEM Brembo brake Pads Organic or Sinter?
    By go_modem_go in forum SL1000 Falco Forum (all years)
    Last Post: 10-14-2005, 03:52 PM
  4. 04 factory OEM and other parts for sale
    By cwalker in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 11-25-2004, 10:42 PM
