Page 3 of 21 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 314
Thread: OEM manufacturers/suppliers
  1. #31
    apriliaforum Junkie Aregata4x4's Avatar
    GA
    I believe that the number 2 stands for 2 sets, but what do I know.
    The mighty oak tree was once a little nut that held its ground.
    ETV1000
  2. #32
    apriliaforum expert olie's Avatar
    Jan 2004
    Hill Country, Texas
    not really, I did check them at the EBC site.
    BTW, the front pads are the same as on the Pegaso and BMW F650. BMW p/n 3411 2345 445.
    The rear pads are common with the Falco, Tuono, Ducs ST2-3&4, MultiStrada, etc
    13 Blue Connie, C14 ABS (GTR 1400), 35k miles
    12 Super T 1200, 55k miles, gone
    09 Red Connie, C14 ABS (GTR 1400), 59k miles, gone
    03 Cappy; 07 Tuonita, both gone but never forgotten
  3. #33
    Jun 2004
    cornwall uk
    Spark Plugs
    www.sparkplugs.com
    for iridium plugs for your capo.
    same plug is listed for all 1000 v twins.
    DCPR9EIX NGK IRIDIUM
    DCPR9E NGK STANDARD
    IXU27 DENSO IRIDIUM TWICE THE PRICE OF NGK
  4. #34
    apriliaforum expert cwalker's Avatar
    sh*tty belgium
    no, the 2 stands for a special version of the pad, means they had to modify an earlier standard pad a bit in order to fit the capo(and maybe also other bikes.)
    so, if you order, make sure you don't forget that "2", or you''l get a slightly different pad!!!
    Ride.In.Peace Jens, my dear friend!
    WWW.QMS.BE !!!!!
    07 rsv factory/project mayhem1... I4's for breakfast...
    07 sxv550/project mayhem2... hypermotards for dinner..... we'll skip lunch....
    it's all extremely funny.....untill somebody gets hurt.....then it gets hilarious!!!!!!
    i've met the 'man in the street'..... and he's a w*nker!
  5. #35
    Jun 2004
    cornwall uk
    Is there a no 2 for the rear pads . If thats the case it may explain the huge problems I had with ebc hh in the rear which no one else has had and ebc were not interested in.
  6. #36
    sh*tty belgium
    i'll check tomorrow, but i guess that might be it, yes!
    WWW.QMS.BE !!!!!
  7. #37
    apriliaforum Junkie Capsil21's Avatar
    Romeoville,IL
    The extra set I have on my garage wall have the # FA209HH
    That is all. No doubt a dealer prompt to make sure two sets are ordered.
  8. #38
    sh*tty belgium
    ebc use the /2 number usually to designate a specific set of special pads. sorry,i haven't had time to check yet, but i'll do that asap!
    WWW.QMS.BE !!!!!
  9. #39
    GA
    ETV1000
  10. #40
    GA
    Oil Filter:
    HiFlo HF152 - made in Japan, around $6.50 at local store.
    ETV1000
  11. #41
    Oct 2003
    Durham, NC
    Permanent (washable) oil filter...
    Another oil filter option that I've not seen mentioned yet: Scotts stainless steel filter. You simply wash it out every oil change, should last forever. At $80 it's not exactly cheap, but a few regular filters would add up to the same and with this I don't have to ride out to my Aprilia dealer (45 minutes away) to buy a filter every time I do an oil change.
    I installed one a few hundred miles ago. So far no problems.
    -Rob-
  12. #42
    apriliaforum prov-nov scarlett11's Avatar
    Aug 2004
    Central Coaster,Cailifornia
    Consolidation?
    Capo Numbers
    Maybe this has been done but I wanted to put some specs in my phone for pertinent trip info. Can anyone add some good info?
    Thanks s2
    brake light = 1157 or 2357LL
    36/41 psi front/rear
    spark = ngk DCPR9E(ix)
    sprocket mod=16t aprilia #0236365
    chain = 112 links
    oil 4.3L=4.50qts=3.82 imp qts
    handlebars = 22mm
    Time to ride!!!! ***********
  13. #43
    Dec 2003
    Lancashire
    WOW!!!! $181 to the UK, including 26.42 postage,you got to be kidding.thats 18 oil filters from M&P uk.think i,ll give it a miss.
    Happy Christmas
    Neil
  14. #44
    Scottsdale, AZ
    Quote Originally Posted by Rob
    -Rob-
    What would you define as a problem, and how would you know if you had it? But aside from that, have you gotten any benefits...other than the total BS on their website? Personally, I'd sooner wash my used toilet paper than fool around washing used oil filters. At least with the toilet paper, I'd know when I'd gotten all the "dirt" out.
  15. #45
    Oct 2003
    Durham, NC
    Quote Originally Posted by Stu_O
    Hi Stu,
    Thank you for your feedback, even if it is a bit high on inflammatory language and low on content...
    To answer your questions: I would define "a problem" as excessive engine wear, which would happen if the filter is not doing its job. The benefit(s) I get is not to have to run out for a filter when I do an oil change, it pays for itself after a few changes, and I like the idea and convenience of re-use rather than throwing away. As to the first, I'll send out an oil sample for analysis (breakdown of metal content/type) with the next oil change and let you know, probably do that again a few oil changes down the road to see if the thing keeps performing.
    Now it's my turn: What exactly is the BS you're mentioning? Their claims seem pretty reasonable to me (as far as their filter is concerned, I've not looked into performance of paper filters and assume they are portrayng them worse than they actually are). As an engineer, I don't see how designing a permanent oil filter is all that hard, these things are not rocket science. One can buy stainless filter membrane sheets with just about any size holes, including 35 micron, so that ain't hard to make or use either. Clogging could be an issue, that's a matter of sufficient filter area and testing under working conditions to see if it holds up. I am of course making the assumption that they did test their product. Cleaning seems fairly straight forward, using a bit of compressed air and solvent. In short, where's the problem?
    Please educate me, I'm always happy to learn. Telling me you'd rather wash out your toilet paper may have comical, but very little educational value...
    -Rob-
  1. Help: Photos of OEM Cup bodywork?
    By smcnamara in forum RS250
    Last Post: 03-08-2007, 02:14 AM
  2. Cheapest place for OEM brake pads?
    By TwinNut in forum SL1000 Falco Forum (all years)
    Last Post: 12-18-2005, 01:45 PM
  3. Are OEM Brembo brake Pads Organic or Sinter?
    By go_modem_go in forum SL1000 Falco Forum (all years)
    Last Post: 10-14-2005, 03:52 PM
  4. 04 factory OEM and other parts for sale
    By cwalker in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 11-25-2004, 10:42 PM
